cyclic boundary condition in OpenFOAM 1.6-ext |
December 6, 2013, 04:44 |
Yu CAO
Rep Power: 13 |
Hi
Does any one who knows how to set cyclic boundary condition in OpenFoam 1.6-ext? It seems different from 2.1.0. I have tried several times but still does not work. Thank you. |
December 7, 2013, 14:06 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Yu,
You can have a look in the following tutorial: ./incompressible/channelFoam/channel395/ Yes, the system is different, as the older versions of OF (OF-1.6-ext included) had the cyclic boundaries on the same patch, such that the cyclic patch has 2N faces in total. The first N faces below to one side of the patch and the other to the second half. Also note that it is required that face 0 matches face N, face 1 matches face N+1, etc. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
December 8, 2013, 05:25 |
#3 | |
Yu CAO
Rep Power: 13 |
Regards Yu |
December 8, 2013, 23:37 |
caoyong
Rep Power: 12 |
Dear Yu,
Have you dealt with the problem of cyclic boundary condition in the older version? I also encountered this and have not gotten the solution. In the channel395 from tutorial, the sides are divided into two patches, one side1 and the other side2. What if put two sides into one patch? Do you have any advice. Thanks in advance. Best regards, So |
December 9, 2013, 16:49 |
#5 | |
Yu CAO
Rep Power: 13 |
Regards Yu |
interFoam and cyclic boundary condition issue | General_Gee | OpenFOAM Running, Solving & CFD | 17 | October 8, 2018 09:33 |
questions about boundary condition type of openfoam 2.2.0 | shuoxue | OpenFOAM Pre-Processing | 3 | May 27, 2013 01:47 |
Axis Boundary condition in OpenFoam | hayhari | OpenFOAM Running, Solving & CFD | 0 | September 20, 2012 05:32 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
