static int debug
Old   December 14, 2013, 06:13
Default static int debug
maybee is on a distinguished road
hi,bool Foam:: pimpleControl::loop()
inter alia in method "bool Foam:: pimpleControl::loop()" can be found a variable called "debug" within the first if condition:
bool Foam::pimpleControl::loop()      //Implements solutionControl.
174*{
175* read();
176*
177* corr_++;  //label corr_ protected, Current corrector loop index. //Class solutionControl
178*
179* if (debug)  //static int debug, Debug Switch , fvSchemes ?
180* {
181* Info<< algorithmName_ << " loop: corr = " << corr_ << endl;
182* }
"static int debug" (for example in class fvSchemes) is defined with :
Debug switch.
So, what is the meaning behind "debug"? Since it is really often used in if conditions of solvers it, I need to know it.
greetings
maybee
maybee is offline   Reply With Quote
Problem with pow and volScalarField _Stefan_ OpenFOAM Programming & Development 15 April 14, 2019 22:20
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 05:35
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
