ForAll Loop
Like Tree4Likes
  • 1 Post By sanj
  • 1 Post By Lieven
  • 1 Post By akidess
  • 1 Post By akidess
Old   January 22, 2014, 20:57
Default ForAll Loop
Sanj M
sanj is on a distinguished road
Hello Guys,
Is there an alternative to the forAll loop? Basically I need to run the following code every time step and as a result it takes a long time. The code is:
forAll(alpha1, celli)
if (alpha1[celli] < 0)
alpha1[celli] = 0;
else if (alpha1[celli] > 1)
alpha1[celli]=1;
else
alpha1[celli]=alpha1[celli];
}//end for loop
This ensures that alpha1 in any cell is always between 0 and 1. I have heard about field operations to make it faster but dont know how to implement it. Can some one please shed some light on this matter.
Thanks,
Sanj
vivek05 likes this.
sanj is offline   Reply With Quote
Old   January 23, 2014, 02:16
Lieven
Lieven will become famous soon enough
I don't think there is a lot of alternative, but you can already simplify (read 'speed up') it a little bit by removing the identity alpha1[celli]=alpha1[celli]:
     alpha1[celli] = 0;
     alpha1[celli]=1;
Or you can write the second 'if' with 'else if'. Nevertheless, it remains an expensive operation.
Cheers,
L
vivek05 likes this.
Lieven is offline   Reply With Quote
Old   January 23, 2014, 05:08
akidess's Avatar
Anton Kidess
Try this:
alpha1 = max(min(alpha1,1.0), 0.0);
vivek05 likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 23, 2014, 12:29
Sanj M
Dear Liven and Anton,
Thanks for your swift responses. I appreciate taking the time to help me.
Lieven: Yes thanks for the code it works perfectly but as you said it is still time expensive.
Anotn: I understand that the max and min will bound the alpha1 values. But, how will it update each cell if celli is missing? Pardon me for my poor knowledge in openfoam and c++.
Thanks,
Sanj
Old   January 23, 2014, 12:44
akidess's Avatar
Anton Kidess
Foam functions are smart. Foam::min / Foam::max will see that you are passing a vol*Field and then automatically know to loop over all cells. You can completely throw out the forAll loop - just this single line will do.
vivek05 likes this.
Old   January 23, 2014, 12:50
Sanj M
Anton,
Thank you so much it worked like a charm!!!
Sanj
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
forAll loop getting stuck? I'm stuck too! CHARLES OpenFOAM Programming & Development 6 October 11, 2013 16:46
basic question with 'ForAll' loop Pascal_doran OpenFOAM Post-Processing 10 December 14, 2012 17:39
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
