September 26, 2013, 07:14 |
Implement a B.C. as a Surface Reaction
Reza
Rep Power: 14 |
I'm working on surface chemistry and I want to implement a chemical reaction on the surface. I think it's possible to use boundary condition as a source or sink term. first of all, which boundary condition is used (or is closest) as a source or sink term? (inletoutlet ??) and also it's possible to define a chemical reaction on the boundary condition? Thank you for your valuable comments. |
September 26, 2013, 09:25 |
#2 | |
mohsen kh
Rep Power: 14 |
Hi dear Gooya
I search for the same problem Iron direct reduction process on a iron pellet. some one suggest me this site,however, I faced a problem in implementation of the solver http://www.catalyticfoam.polimi.it/ I think it might be relevant to your case of study cheers Mohsen if you Quote:
September 26, 2013, 12:16 |
#3 | |
Reza
Rep Power: 14 |
Hi Mohsen,
I saw this site but it does not seems applicable!!! Although I will go through it. Thanks Quote:
February 12, 2014, 10:20 |
Solver for OpenFOAM with Catalysis
Matthias Hettel
Rep Power: 15 |
Hello Everybody,
you can find also an OpenFOAM solver which makes use of the software toolbox DETCHEM. The properties, gasphase reactions and surface reactions are taken from a shared library. For academic use this code is free, for industrial use you have to buy a part of the DETCHEM software. You find information at www.detchem.com. Click on Software on the left side and have a look to the entry "DC4OpenFOAM" in the product list. Greetings matthi |
boundary condition, reaction |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Defining reaction rate with multiple surface reaction | Fred Marias | FLUENT | 1 | September 12, 2013 04:56 |
UDF macros for surface reaction | borhan_sd@yahoo.com | Fluent UDF and Scheme Programming | 0 | June 6, 2013 08:57 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Surface reaction rate temperature dependence | tumbao | FLUENT | 1 | February 17, 2011 09:14 |
