max iterations exceded in CHT
Old   February 13, 2014, 10:44
Default max iterations exceded in CHT
AJ
Aj Nair is on a distinguished road
i tried CHT with 2 fluids above a solid but unfortunately i am getting Maximum Iteration exceed on the fluid solving part, i tried changing the relaxation factor and even MaxIter_ , it was not beneficial. And the temperature involved is around 270 to 370 K and other BCs are seem to be fine.any suggestions??
And second doubt i have is, how can i confirm if solid and fluid patches are coupled.Because i made three cellzones using salome. and used splitMeshRegions -cellZone in Foam to form separate polymesh file. After splitting the interface automatically was categorized as type mapped wall.Is my procedure right??. This question arise because my solid temperature haven't changed a bit.
P.S: i saw many threads on "Maximum Iteration exceed" but i was not able to solve, which made me to post this
Aj Nair is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
