mass transport having different diffusity in each direction
Old   November 8, 2013, 05:27
Default mass transport having different diffusity in each direction
Baek, Donghae
wes1204 is on a distinguished road
hello foamer
I am making my own solver related to mass transport in turbulent flow.
first, i made the solver of mass transport having same diffusity of concentration in each direction like:
fvScalarMatrix CEqn
fvm::ddt(C)
+ fvm::div(phi, C)
- fvm::laplacian(turbulence->nut() / 0.5, C)
CEqn.solve();
the code above is added pimple solver to calculate concentration C.
this solver is for river flow and turbulent diffusity of mass is
nut() / 0.5
it is eddy-viscosity over Prandtl number(in this case, Prandtl number is 0.5)
that is, mass spread out having same diffusion coefficient in x,y,z
but now, i want to consider different coefficient in each direction like attached equation.
different coefficient is definded D1, D2, D3 as scalar.
D1, D2, D3 is calculated by some equations.
if scalar value D1, D2, D3 can be located in vector matrix after D1,D2,D3 is calculated, i think it is easy to programming as i want.
like:
Dt=(D1, D2, D3)
fvScalarMatrix CEqn
fvm::ddt(C)
+ fvm::div(phi, C)
- Dt&fvm::laplacian( C)
CEqn.solve();
actually i dont know openfoam programming exactly.
I am just beginer for programming.
so i'm not sure whether - Dt&fvm::laplacian(C) is right expression in openfoam language or not
plz help me.
the point is make vector using scalar which is calculated
wes1204 is offline   Reply With Quote
Old   February 10, 2014, 09:01
Joachim Herb
jherb is on a distinguished road
If you haven't solved your problem meanwhile: Here is the documentation of the OpenFOAM operators:
http://www.foamcfd.org/Nabla/guides/...sGuidese4.html
jherb is offline   Reply With Quote
Old   February 21, 2014, 15:45
Jay
jdmac6 is on a distinguished road
Did you ever figure this out? What is the syntax to access the components of the vector Dt in fvScalarMatrix?
jdmac6 is offline   Reply With Quote
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
questions about species transport through walls shuqin FLUENT 13 April 9, 2014 02:42
why my momentum and mass not convergence wwwuxing CFX 3 May 18, 2012 07:49
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 10:09
Coupled mass and heat transport yves OpenFOAM Running, Solving & CFD 1 May 5, 2006 05:33
