Temperature dependent viscosity (Carreau-Yasuda)
Old   May 6, 2016, 08:48
Default Temperature dependent viscosity (Carreau-Yasuda)
open is on a distinguished road
New OpenFoam (2.4) user!
As per the title... I wish to use a temperature dependent viscosity model. I've seen various posts and papers on this so I've followed the example modifying the power law - that compiles ok.
My next step was to take the BirdCarreau and modify to suit Carreau-Yasuda:
u=u0 * alpha * [lambda * alpha * strainrate + 1]^((n-1)/2)
alpha = exp[beta * (1/T - 1/Tref)]
TempCarreauYasuda.C (header also modified)
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::TempCarreauYasuda::calcNu() const
    const volScalarField& T= U_.mesh().lookupObject<volScalarField>("T");
    return max
    nuInf_,
        nu0_ * Foam::exp(beta_ * (1.0/T - 1.0/Tref_) )
    *pow(lambda_ * Foam::exp(beta_ * (1.0/T - 1.0/Tref_) ) * strainRate() + scalar(1), (n_ - 1.0)/a_)
transportProperties
TempCarreauYasudaCoeffs
    nu0             nu0 [ 0 2 -1 0 0 0 0 ] 7.191; // 5645/rho
    nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1.2739e-03; // 1/rho
    lambda          lambda [ 0 0 -1 0 0 0 0 ] 0.28;
    n               n [ 0 0 0 0 0 0 0 ] 0.61;
    beta            beta [ 0 0 0 1 0 0 0 ] 6330.0;
    Tref            Tref [ 0 0 0 1 0 0 0 ] 473.15;
    a               a [ 0 0 0 0 0 0 0 ] 2.0; // can omit as will default to 2
Question 1: how can I define
as a variable to avoid repetition?
Question 2: The code compiles without error. Why is the following error occurring:
Selecting incompressible transport model TempCarreauYasuda
--> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
     dimensions : [0 0 -2 0 0 0 0] + [0 0 0 0 0 0 0]
    From function operator+(const dimensionSet&, const dimensionSet&)
    in file dimensionSet/dimensionSet.C at line 478.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:?
#3  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator+<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) at ??:?
#4  Foam::viscosityModels::TempCarreauYasuda::calcNu() const at ??:?
#5  Foam::viscosityModels::TempCarreauYasuda::TempCarreauYasuda(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#6  Foam::viscosityModel::adddictionaryConstructorToTable<Foam::viscosityModels::TempCarreauYasuda>::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#7  Foam::viscosityModel::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#8  Foam::singlePhaseTransportModel::singlePhaseTransportModel(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#9  ? at ??:?
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11  ? at ??:?
It looks like a dimension problem but I'm not sure why.
open is offline   Reply With Quote
Old   May 6, 2016, 09:01
Question 2 is resolved... I notice that I specified incorrect units in the transportProperties.
The full source code is attached (no guarantees) to help other beginners.
Still looking for guidance with the first question.
Old   May 9, 2016, 02:51
TobM is on a distinguished road
Do you mean something like that?
    volScalarField test = Foam::exp(beta_ * (1.0/T - 1.0/Tref_) );
    return max
        nuInf_,
      * pow(lambda_ * test * strainRate() + scalar(1), (n_ - 1.0)/a_)
I hope it works...
TobM is offline   Reply With Quote
Old   June 21, 2016, 08:35
Originally Posted by TobM View Post
I hope it works...
Forgot to post back; yes works, and thank you for your help.
openfoam, temperature, viscosity
Temperature dependent SURFACE TENSION TEMPERATURE COEFFICIENT kcgmech Fluent UDF and Scheme Programming 1 November 22, 2016 17:01
Adding new temperature dependent viscosity model vabishek OpenFOAM Programming & Development 3 May 15, 2016 21:05
Temperature dependent density in transportProperties when using polynomials GregorAlan OpenFOAM Running, Solving & CFD 0 February 11, 2016 05:29
Temperature dependent Non-Newtonian viscosity UDF cric92 Fluent UDF and Scheme Programming 0 April 14, 2013 06:31
Pressure & Temperature dependent EOS hennas FLUENT 1 October 31, 2011 17:55
