if (timestep X == true) OR if (current_timestep == timestep X)
Old   March 14, 2014, 08:43
Default if (timestep X == true) OR if (current_timestep == timestep X)
maybee is on a distinguished road
hi,
I need to implement specific code for specific timesteps. Therefore I though about doing something like
if (timestep X == true) {...}
OR if
(current_timestep == timestep X) {...}
Does someone know how I can do so?
greetings
maybee
maybee is offline   Reply With Quote
Old   March 14, 2014, 09:32
Hi again,
I found
scalar deltaTValue	() const inline
//Return time step value.
and
Foam::label timeIndex	() const
//Return current time index.
and
Foam::dimensionedScalar deltaT	() const
//Return time step.
I guess the first one will give me the whole value of the time step, e.g. 5 Seconds, right?
But what about the second and the third one? Which one will just give me the number of timesteps including the actual running time step?
Old   March 14, 2014, 11:45
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Since this sounds like you are doing it in a solver, runTime.value() is your friend.
mturcios777 is offline   Reply With Quote
Old   March 14, 2014, 13:26
Thx, for the help. Just to be sure: runTime.value() will return the following values:
first time loop pass: 0
second time loop pass: 1
third time loop pass : 2
and so on
Old   March 14, 2014, 13:28
Marco A. Turcios
So you want the condition to run when t = a certain value, or dt = a certain value? I may have misunderstood your initial question.
Old   March 14, 2014, 15:07
I want to do something like:
if (time loop pass == 1)
if (time loop pass == 2)
Sure, I can do this without using any members of class Time, but I thought if Time provides such a member it would be better to use it.
Old   March 17, 2014, 02:30
Christian Butcher
chrisb2244 is on a distinguished road
I think the confusion is about what sort of 'time' you want to measure.
Within a solver, runTime.value() will return the 'real', physical time, in seconds.
If you want to count the number of iterations of your code, a counter might be a better bet?
runTime.value() will return these values if your deltaT is 1 second per iteration.
and so on
Although actually, the solvers that I've looked at mostly start with a runTime++; , so they'd return 1 as the first time value if dt = 1 and you took it after that line
chrisb2244 is offline   Reply With Quote
Old   March 17, 2014, 03:52
hi,
thx for the reply. I ve taken an own counter now. This should work fine for me . As I already told - just wanted to check if class Time or any other class already proivdes such a counter.
greetings
maybee
Modifying sonicFoam to run with variable timestep - strange results dalaron OpenFOAM Programming & Development 1 September 2, 2013 07:21
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 00:37
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 01:04
Adequate timestep selection for multidomain problem gerardosrez CFX 6 November 28, 2010 17:50
Timestep study ijk CFX 6 April 9, 2010 07:38
