Feed stream (multiphaseEulerFoam)
Like Tree1Likes
  • 1 Post By dschmidt
Old   March 26, 2014, 09:06
Default Feed stream (multiphaseEulerFoam)
maybee is on a distinguished road
hi,
I need to know how and where the feed stream is calculated/formed? In tutorial-case "bubbleColumn" of multiphaseEulerFoam are besides other files are files for the velocity of the phases and the alphas of the phases.
Within a velocity file can be found:
inlet
        type               fixedValue;
        value              uniform (0 0.1 0);
Within a alpha file can be found:
inlet
        type            fixedValue;
        value           uniform 0.5;
Within the boundary file in bubbleColumn/constant/polyMesh can be found:
inlet
        type            patch;
        nFaces          25;
        startFace       3650;
Three questions:
1.I guess the feed streams of each phase are somehow calculated by this data, right?
2.How are the feed streams of each phase calculated?
3.Where and in which object/variable are these feed streams for each phase are stored?
greetings maybee
maybee is offline   Reply With Quote
Old   April 4, 2014, 06:53
Dominik Schmidt
dschmidt is on a distinguished road
If you use:
inlet
type                          flowRateInletVelocity;
volumetricFlowRate    constant 0.1;  //m3/s
value                         uniform (0 0 0);
your feed rate [m3/s] is calculated as:
alpha_phase_inlet x volumetricFlowRate value
Otherwise it's calculated with the face area of the inlet, the inlet velocity and the alpha value of the phase.
maybee likes this.
dschmidt is offline   Reply With Quote
UDF for stream function and heatlines guilbemloco Fluent UDF and Scheme Programming 2 August 7, 2020 10:30
Stream is sticking to the wall pawel123 FLUENT 0 October 18, 2013 06:38
Compute 3D stream surfaces? Jonas Holdeman Main CFD Forum 1 April 24, 2013 12:18
Streamfunction? cain Main CFD Forum 5 July 19, 2012 10:05
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 09:16
