Compilation error
Prev Previous Post   Next Post Next
Old   April 8, 2014, 16:52
Default Compilation error
India
mayank.dce2k7 is on a distinguished road
Hi Foamers,
I copied icoFoam solver folder from /opt/openfoam222/applications/solvers/incompressible/icoFoam and placed it in my working directory. I made following changes:
1.) Renamed icoFoam folder to micoFoam
2.) Renamed icoFoam.C to micoFoam.C
3.) In Make/files changed icoFoam.C to micoFoam.C
and also changed FOAM_APPBIN/icoFoam to FOAM_USER_APPBIN/micoFoam
I went inside micoFoam directory and typed wmake. I got the following error:
Making dependency list for source file micoFoam.C
SOURCE=micoFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/sampling/lnInclude -IlnInclude -I. -I/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude -I/usr/local/apps/foam/gnu44ThirdParty-2.1.1/ParaView-3.14.1-Linux-64bit/bin/include/paraview- -fPIC -c $SOURCE -o Make/linux64Gcc45DPOpt/micoFoam.o
/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’
/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’
/usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’
mkdir: `': No such file or directory
make: *** [/micoFoam] Error 1
I don't understand the last two line:
when i compiled above 'micoFoam' on my laptop it compiled. Now I am compiling it on cluster and it is giving me above error. Any ideas what is lacking?
Regards,
Mayank
mayank.dce2k7 is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
