Whats wrong with this volScalarField?
Like Tree7Likes
  • 2 Post By alexeym
  • 1 Post By sharonyue
  • 1 Post By alexeym
  • 2 Post By alexeym
  • 1 Post By alexeym
Old   April 9, 2014, 04:09
Default Whats wrong with this volScalarField?
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
In my code I have this We definition:
volScalarField We(2*rho2*pow(epsilon,0.6667)*pow(d,1.6667));
Then I define:
volScalarField Web(-1.5*(1/We));
It compiles okay, and actually I only define this Web, I even dont use it in function. But when I run a case it said:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4  void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(double const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
 at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Floating point exception (core dumped)
I tried another definition:
volScalarField Web(-1.5*(pow(We,-1));
It compiles okay too, but when I run it said:
#3   in "/lib/x86_64-linux-gnu/libm.so.6"
#4  pow in "/lib/x86_64-linux-gnu/libm.so.6"
#5  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:?
#6  void Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:?
#7  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:?
#8  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, double const&) at ??:?
 at ??:?
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
So I think this core dumped is caused by this definition. How should I do? Thanks.
PS. If I define it like this:
volScalarField Web(-1.5*(pow(We,1));
It runs with out error.
sharonyue is offline   Reply With Quote
Old   April 9, 2014, 04:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
as the error is in division, it seems that We is zero somewhere.
sharonyue and venturi123 like this.
alexeym is offline   Reply With Quote
Old   April 9, 2014, 04:36
Dongyue Li
Originally Posted by alexeym View Post
Solved! You do pretty good in OpenFOAM, everytime you know the solution.!
Old   April 9, 2014, 04:38
Alexey Matveichev
This time it's just common sense
Old   April 18, 2014, 16:16
Amjad
Amjad Asad is on a distinguished road
hallo
how did u solve this problem plz
Amjad Asad is offline   Reply With Quote
Old   April 18, 2014, 21:12
Dongyue Li
Originally Posted by Amjad Asad View Post
hallo
Just like Alexey have said,
when you are using pow() function. Watch out your denominator, it can not be zero. So if you wanna use this function as this: pow(e,-1). You'd better define a small number like SMALL=1e-6, and write it as pow(e+SMALL,-1). This worked for my problem.
Regards,
Amjad Asad likes this.
Old   April 19, 2014, 00:52
Amjad
I am trying to write a code to estimate the turbulence intensity in openfoam. the code does not work, when mag (U) is equal to zero.
volScalarField Intensity
IOobject
"Intensity",
runTime.timeName(),
mesh,
IOobject::NO_READ
sqrt((2.0/3.0)*k)/mag(UMean)
Old   April 19, 2014, 01:45
Alexey Matveichev
instead of
you can use
sqrt((2.0/3.0)*k)/max(SMALL, mag(UMean))
Old   April 19, 2014, 02:02
Amjad
thanks for ur reply but i have a new problem now, I get
--> FOAM FATAL ERROR:
Arguments of max have different dimensions
dimensions : [0 0 0 0 0 0 0] and [0 1 -1 0 0 0 0]
thanks
Old   April 19, 2014, 02:06
Alexey Matveichev
Oh, forgot about dimensions. Then it should be something like:
sqrt((2.0/3.0)*k)/max(dimensionedScalar("uSMALL", dimVelocity, SMALL), mag(UMean))
Amjad Asad and sharonyue like this.
Old   April 19, 2014, 02:09
Amjad
thanks it is working very good now
Old   April 19, 2014, 04:02
Amjad
hi again,
but i still get strange values at the wall where the velocity zero
Old   April 19, 2014, 04:09
Alexey Matveichev
And by strange values you mean? What BCs did you use for k on this wall with non-slip BC for velocity?
Old   April 19, 2014, 04:20
Amjad
i meant with strang values that they are too hight 1e+13. and the BCs is fixed wall and i used wall function here for K
Old   April 19, 2014, 07:23
Alexey Matveichev
OK.
Let's forget for a moment about volume fields. If you have expression y/x in your model, rewriting it as y/(x + small) will help you to resolve a problem with 0/0. But it will give you very high values if y is non-zero.
Now returning to OpenFOAM. You've got non-slip BC for velocity at the wall and you've got non-zero value of k at the same wall. Why? If there's no motion why there is turbulence? If you're using kqRWallFunction for k, it's actually simple zero-gradient boundary condition and you have to use appropriate mesh so k go to 0 at the wall. Or maybe your solution is not converged. Or maybe your initial conditions do not make sense. Or ...
First fix your model, then fix code.
Old   April 19, 2014, 08:21
Amjad
thanks for ur help, I think there is no proplem with K. the problem is mag(U) because it too small
at the wall, them K/mag(u) will be too high.
my code is attached.
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
udf error srihari FLUENT 1 October 31, 2016 14:18
make a dimensionedScalar to be volScalarField sharonyue OpenFOAM Programming & Development 4 April 2, 2014 05:44
multiplicate all elements of volScalarField with scalar to get new volScalarField maybee OpenFOAM Programming & Development 2 February 18, 2014 15:43
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
