Remove particle in solidParticleFoam
Like Tree2Likes
  • 1 Post By shchepan
  • 1 Post By AMahrla
Old   August 11, 2011, 02:07
Default Remove particle in solidParticleFoam
Mihails Ščepanskis
shchepan is on a distinguished road
I am working with solidParticle library within OpenFOAM-1.6. I coded additional function, which change particle diameter due to the diffusion process. This function is implemented in solidParticleFoam before move function.
Now I need to remove from the cloud particles with diameters close to zero. Is there any function to remove (delete) particle from the cloud?
houwy likes this.
Mihails Ščepanskis
Laboratory for Mathematical Modelling of Environmental and Technological Processes
University of Latvia
shchepan is offline   Reply With Quote
Old   August 11, 2011, 09:25
Stephanie Geier
steffi_geier is on a distinguished road
Hi Mihails,
I think you can delete particles if you change
td.keepParticle = true;
to
td.keepParticle = false;
for the particles which are too small for you.
You will find the line
within the function "move".
Hope this will help you
Steffi
steffi_geier is offline   Reply With Quote
Old   August 11, 2011, 10:41
Mihails Ščepanskis
Dear Steffi,
thank you for answer.
Line td.keepParticle = true; is situated in the begin of move function. If I'll code somewhere in this function
HTML Code:
if (d_<=0.0)
it will remove this particle only ones for move function. Every next step move function will check this if again. But I want totally delete this particle.
I created new function sizeEvolution(), which has no argument of td. This function is implemented in the solver before move function. So I want to delete particles with zero size within sizeEvolution function. How can I do it?
Mihails Ščepanskis
Old   August 12, 2011, 04:50
Astrid Mahrla
AMahrla is on a distinguished road
Possibly you could try to use the "deleteParticle" function of basic cloud (find the definition in Cloud.C or here in the doxygen) ?
mbookin likes this.
AMahrla is offline   Reply With Quote
Old   August 12, 2011, 07:29
Mihails Ščepanskis
Perfectly! Thank you, Astrid!
Mihails Ščepanskis
Old   September 8, 2013, 18:33
India
mayank.dce2k7 is on a distinguished road
Can any of you tell me how to calculate/count particle escaping from a patch in solidParticleFoam?
Regards,
Mayank
mayank.dce2k7 is offline   Reply With Quote
Old   March 28, 2014, 07:25
houwy
houwy is on a distinguished road
Hello! I want change particle diameter due to the diffusion process. How can I do it! What function did you add.
houwy is offline   Reply With Quote
Old   April 14, 2014, 09:56
houwy
Originally Posted by mayank.dce2k7 View Post
Regards,
Mayank
Have you solved your problem?
Old   April 16, 2014, 17:29
India
Yaa, I did. But I am using icoUncoupledKinematicPartcelFoam. It has in-built functionality of counting particles. I was unable incorporate that functionality in solidParticleFoam though.
DPM particle time step amos FLUENT 1 January 4, 2020 08:46
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
solidParticleFoam particle positions caw OpenFOAM Running, Solving & CFD 1 October 6, 2009 03:50
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
