April 17, 2014, 14:31 |
Adding temperature to pisoFoam
RD
Rep Power: 12 |
Hi All,
If someone has successfully added temperature to pisoFoam solver, I request you to share your Solver folder (one with *.C and createFields.H files) and any one of your case folders (with '0', 'Constant' and 'System' folders) which you have successfully run. I have successfully added temperature to icoFoam using the instructions given here: HTML Code:
http://openfoamwiki.net/index.php/How_to_add_temperature_to_icoFoam Using the same procedure, I added temperature to pisoFoam also and the solver runs fine. I just want to confirm the correctness of my solver. Please provide some help. Thanks in advance. |
April 17, 2014, 23:41 |
Dongyue Li
Rep Power: 17 |
Createfields
Info<< "Reading field p\n" << endl; volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field T\n" <<endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); dimensionedScalar DT ( transportProperties.lookup("DT") ); # include "createPhi.H" label pRefCell = 0; scalar pRefValue = 0.0; setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue); singlePhaseTransportModel laminarTransport(U, phi); autoPtr<incompressible::turbulenceModel> turbulence ( incompressible::turbulenceModel::New(U, phi, laminarTransport) ); Code:
int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "readPISOControls.H" #include "CourantNo.H" // Pressure-velocity PISO corrector { // Momentum predictor fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) ); UEqn.relax(); if (momentumPredictor) { solve(UEqn == -fvc::grad(p)); } // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, U, phi) ); adjustPhi(phiHbyA, U, p); // Non-orthogonal pressure corrector loop for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { // Pressure corrector fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); if ( corr == nCorr-1 && nonOrth == nNonOrthCorr ) { pEqn.solve(mesh.solver("pFinal")); } else { pEqn.solve(); } if (nonOrth == nNonOrthCorr) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ); TEqn.solve(); } } turbulence->correct(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } |
April 18, 2014, 14:31 |
Adding Temperature to pisoFoam
RD
Rep Power: 12 |
Thanks for posting your files sharonyue.
I have one change in my solver file. I kept the TEqn outside the piso loop. Which one is correct? Also, I've seen many people using kappat while adding temperature to pisoFoam. Please help me to understand kappat and it's significance |
April 18, 2014, 15:48 |
would you like to reimplement buoyantBoussinesqPimpleFoam (with thermal expansion coefficient equal to zero, as you did not modify momentum equations)? In that solver temperature equation is solver just after velocity equation. UPD. kappat is turbulent heat conductivity. If you're planning to simulate heat transfer in turbulent flow, then you should account for it, otherwise, you can forget about it. |
April 18, 2014, 21:05 |
#5 | |
Dongyue Li
Rep Power: 17 |
And whether to put it in or out piso loop(after turbulence correction). I just made a comparison too. It is totally the same without any difference... See the picture. So I think put it out of the loop is better to save more calculating time. Regards, |
April 19, 2014, 01:41 |
if you'd like to create this solver for the sake of creation of the solver, then you should also add buoyancy force to momentum equation. If you'd like to have this solver for practical reasons (running simulations, obtaining results) then you can just use buoyantBousinesqPimpleFoam. And if you like it to behave like "pisoFoam with temperature and buoyancy" set number of outer correctors (nOuterCorrectors in PIMPLE dictionary) to 1. |
April 19, 2014, 02:00 |
#9 |
OK. Set beta (thermal expansion coefficient) to zero and there will be no buoyancy in buoyantBoussinesqPimpleFoam.
Or if you'd like to go with "your own" solver, here is how turbulent heat diffusivity is calculated: Code:
alphat = turbulence->nut()/Prt; alphat.correctBoundaryConditions(); volScalarField alphaEff("alphaEff", turbulence->nu()/Pr + alphat); |
April 19, 2014, 15:32 |
#11 |
RD
Rep Power: 12 |
Hi alexeym,
I've successfully added temperature to pisoFoam by following your inputs. Thanks a lot. I've another question. I want to set a constant heat flux (q w/m2) boundary condition on a wall. I did it this way: Code:
wall { type fixedGradient; gradient uniform 100; } Is this correct? |
April 19, 2014, 16:11 |
#12 |
no, it won't be correct, you need heat transfer coefficient (http://en.wikipedia.org/wiki/Heat_transfer_coefficient). |
April 20, 2014, 02:38 |
#13 |
RD
Rep Power: 12 |
Oh! Then how to implement this constant heat flux bc? I'm totally confused.
April 20, 2014, 05:15 |
#14 |
Well...
start with description of the problem, as "...forced convection heat transfer problem..." is not enough (you'd like to use q = hc*(T - Tinf) relation for calculation of heat flux, it OK, but to calculate that hc one needs to know more about problem). Then Code:
$ cd $FOAM_SRC $ find . -iname '*wallHeat*' |
April 20, 2014, 06:58 |
#15 |
RD
Rep Power: 12 |
Problem is flow of water through a square duct. At one wall of the duct, I want to give constant heat flux. Want to run both laminar and turbulent cases. For laminar case i'm using modified icoFoam and for turbulent, modified pisoFoam.
So I have to find h for my problem, then from q=h*(T-Tinf) I can get T. Then the temperature bc is a uniform fixedValue? Is that the way? |
April 20, 2014, 12:28 |
#16 | ||
1. You've got heat transfer from fluid into a wall and them heat transfer inside the wall. And three temperatures T_fluid, T_wall (temperature of a wall near the fluid interface), T_inf (temperature of the wall at the infinity). You'd like to estimate hc of the system, so you can write q = hc*(T_fluid - T_inf) 2. 1/hc = 1/hc_flud->wall + 1/hc_wall. As we have got fluid, we can assume ideal contact with the wall, so 1/hc_fluid->wall will be equal 0 (so T_wall = T_fluid). 3. Heat transfer coefficient inside the wall can be estimated as kappa_wall/L_wall, where kappa_wall is heat conductivity of the wall material, L_wall is the thickness of the wall. And finally if your wall thickness is zero, then yes, BC should be fixed value with T_inf. |
April 22, 2014, 17:50 |
#17 |
Joachim Herb
Rep Power: 21 |
I think you are looking for the turbulentHeatFluxTemperature boundary condition:
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H |
pisofoam, temperature.add |
Adding temperature equation to porousSimpleFoam | David_010 | OpenFOAM Programming & Development | 9 | February 14, 2018 01:22 |
chtMultiRegionSimpleFoam: strange error | samiam1000 | OpenFOAM Running, Solving & CFD | 26 | December 29, 2015 22:14 |
Problems adding temperature to icoFoam | sur4j | OpenFOAM Programming & Development | 8 | January 11, 2015 01:14 |
pisoFoam LES turbulent model + temperature | Byxon | OpenFOAM Programming & Development | 0 | October 4, 2013 06:55 |
Adding Temperature in channelFoam | dhruv | OpenFOAM | 10 | May 5, 2012 05:40 |
