why the function linearInterpolate(phi) can be directly used?
Like Tree1Likes
  • 1 Post By huyidao
Old   November 4, 2015, 10:12
Default why the function linearInterpolate(phi) can be directly used?
nemo
huyidao is on a distinguished road
Hello.
In this wiki page
https://openfoamwiki.net/index.php/O...eInterpolation,include this sentence:
"The linear scheme is explicitly included with fvCFD.H, a file that at the top level of most solvers. To specifically force a linear interpolation:
linearInterpolate(phi);"
But I do not understand this,can anyone explain this to me why in the createPhi.H the linearInterpolate(U) can be directly used?THe linearInterpolate() is a part of the class linear..,it confuses me.
huyidao is offline   Reply With Quote
Old   November 5, 2015, 05:50
Hassan Kassem
hk318i is on a distinguished road
Originally Posted by huyidao View Post
Hello.
In this wiki page
This sentence means that fvCFD.H includes the linear interpolation (linear.H), therefore it is available for every solver.
linearInterpolate() can be directly used because it is a function not a class. To be more precise it is a template function which calls surfaceInterpolationScheme::interpolate static function. linearInterpolate() is defined in linear.H.
Bw,
Hassan
hk318i is offline   Reply With Quote
Old   November 5, 2015, 06:34
nemo
Thank you.
I finally realize my stupid mistake..I did not read the code carefully..
The function linearInterpolate is not part of class linear.It is defined in the namespace Foam.
template<class Type>
class linear
public surfaceInterpolationScheme<Type>
// Private Member Functions
//- Disallow default bitwise assignment
void operator=(const linear&);
public:
//- Runtime type information
TypeName("linear");
// Constructors
//- Construct from mesh
linear(const fvMesh& mesh)
surfaceInterpolationScheme<Type>(mesh)
//- Construct from Istream
linear(const fvMesh& mesh, Istream&)
//- Construct from faceFlux and Istream
linear
const fvMesh& mesh,
const surfaceScalarField&,
Istream&
// Member Functions
//- Return the interpolation weighting factors
tmp<surfaceScalarField> weights
const GeometricField<Type, fvPatchField, volMesh>&
) const
return this->mesh().surfaceInterpolation::weights();
//class linear ends here..
//The linearInterpolate is not a part of class linear
//It is defined in namespace Foam
tmp<GeometricField<Type, fvsPatchField, surfaceMesh> >
linearInterpolate(const GeometricField<Type, fvPatchField, volMesh>& vf)
return surfaceInterpolationScheme<Type>::interpolate
vf,
vf.mesh().surfaceInterpolation::weights()
linearInterpolate(const tmp<GeometricField<Type, fvPatchField, volMesh> >& tvf)
tmp<GeometricField<Type, fvsPatchField, surfaceMesh> > tinterp =
linearInterpolate(tvf());
tvf.clear();
return tinterp;
} // End namespace Foam
Michael@UW likes this.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
