October 17, 2014, 10:01 |
Segmentation Fault caused by a pointer
Kevin van As
Rep Power: 20 |
I am writing a custom CloudFunctionObject, which I based on "ParticleTrap". Code:
vi $FOAM_SRC/lagrangian/intermediate/submodels/CloudFunctionObjects/ParticleTrap/ParticleTrap.C Without using parallelisation, I get the following output/error, including my test messages: Code:
Solving 2-D cloud inclusion [0] preEvolve begins. [0] alphaInterpPtr_.valid()? 0 [0] alphaInterpPtr_.empty()? 1 [0] cellI of (0,0.015,0) = 59899 [0] start of if-scope. [0] alpha has been found. [0] alphaPtr_ is set. [0] interpolator is constructed [0] alphaInterpPtr_ is set. [0] INSIDE scope test: [0] alpha at cellCenter = 0 [0] alpha at (0,0.015,0) = 0 [0] alphaInterpPtr_.valid()? 1 [0] alphaInterpPtr_.empty()? 0 [0] OUTSIDE scope test: [0] alpha at cellCenter = 0 [0] alpha at (0,0.015,0) = 0 [0] OUTSIDE scope test: [0] alpha at cellCenter = 0 [0] alpha at (0,0.015,0) = 0 [0] POSTMOVE begin [0] p.origId() = 0 [0] POSTMOVE --> cellI of (0,0.015,0) = 59899 [0] alphaInterpPtr_.valid()? 1 [0] alphaInterpPtr_.empty()? 0 [0] POSTMOVE scope test: [0] alpha at cellCenter = 0 #0 Foam::error::printStack(Foam::Ostream&) in "/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::kvaParticleCaptureAndHold<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >::postMove(Foam::KinematicParcel<Foam::particle>&, int, double, Foam::Vector<double> const&, bool&) in "/home/A077594/OpenFOAM/A077594-2.3.x/platforms/linux64GccDPOpt/lib/libcustomCloudFunctionObjects_v3.so" #4 Foam::CloudFunctionObjectList<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >::postMove(Foam::KinematicParcel<Foam::particle>&, int, double, Foam::Vector<double> const&, bool&) in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #5 bool Foam::KinematicParcel<Foam::particle>::move<Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > > >(Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >&, double) in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #6 void Foam::InjectionModel<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >::inject<Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > > >(Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >&) in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #7 void Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > >::evolveCloud<Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > > >(Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >&) in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #8 void Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > >::solve<Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > > >(Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >&) in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #9 Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > >::evolve() in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #10 Foam::EvolveCloudFunctionObject<Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > > >::execute(bool) in "/apps/OpenFOAM/site/2.3.x/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so" #11 Foam::functionObjectList::execute(bool) in "/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #12 Foam::Time::run() const in "/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #13 main in "/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/interFoam" #14 __libc_start_main in "/lib64/libc.so.6" #15 __gxx_personality_v0 in "/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/interFoam" Segmentation fault More specifically, the line which crashes is: Code:
scalar testVal = alphaInterpPtr_->interpolate(testPoint, testCell); //Does the pointer work? Code:
alphaInterpPtr_.clear(); Not using the autoPtr class, but a regular C-pointer (VariableName*), will yield exactly the same result. Question: Does anyone know what goes wrong? Or alternatively, does someone know a work-around / good practice to use? (I'm trying not to construct a new interpolationCellPoint<scalar> in each postMove(), since it will be called thousands of times per iteration.) --- Code Appendix --- Snippet from the header: Code:
#include "CloudFunctionObject.H" #include "volFields.H" #include "interpolationCellPoint.H" class kvaParticleCaptureAndHold : public CloudFunctionObject<CloudType> { //- Pointer to the volume fraction field const volScalarField* alphaPtr_; autoPtr<interpolationCellPoint<scalar> > alphaInterpPtr_; //const interpolationCellPoint<scalar>* alphaInterpPtr_; public: //- Pre-evolve hook virtual void preEvolve(); //- Post-evolve hook virtual void postEvolve(); //- Post-move hook virtual void postMove ( typename CloudType::parcelType& p, const label cellI, const scalar dt, const point& position0, bool& keepParticle ); } C-file (preEvolve()): (For a single processor, this code executes without a problem. In parallel, this code crashes. This is probably for the same reason as my serial code crashes in postMove(), so let's ignore that for now.) Code:
template<class CloudType> void Foam::kvaParticleCaptureAndHold<CloudType>::preEvolve() { Sout << "[" << Pstream::myProcNo() << "] " << "preEvolve begins." << nl; Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_.valid()? " << (alphaInterpPtr_.valid()) << nl; Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_.empty()? " << (alphaInterpPtr_.empty()) << nl; vector testPoint(0.,0.015,0.); label testCell = this->owner().mesh().findCell(testPoint); Sout << "[" << Pstream::myProcNo() << "] " << "cellI of (0,0.015,0) = " << testCell << nl; if (alphaPtr_ == NULL) { Sout << "[" << Pstream::myProcNo() << "] " << "start of if-scope." << nl; const fvMesh& mesh = this->owner().mesh(); const volScalarField& alpha = mesh.lookupObject<volScalarField>(alphaName_); Sout << "[" << Pstream::myProcNo() << "] " << "alpha has been found." << nl; alphaPtr_ = α Sout << "[" << Pstream::myProcNo() << "] " << "alphaPtr_ is set." << nl; interpolationCellPoint<scalar> alphaInterp(*alphaPtr_); Sout << "[" << Pstream::myProcNo() << "] " << "interpolator is constructed" << nl; alphaInterpPtr_.set(&alphaInterp); Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_ is set. " << nl; if(testCell != -1){ //if point is inside mesh (of the current processor) Sout << "[" << Pstream::myProcNo() << "] " << "INSIDE scope test: " << nl; scalar alphaAtP = alphaPtr_->internalField()[testCell]; //Does the pointer work? Sout << "[" << Pstream::myProcNo() << "] " << "alpha at cellCenter = " << alphaAtP << nl; scalar testVal = alphaInterpPtr_->interpolate(testPoint, testCell); //Does the pointer work? Sout << "[" << Pstream::myProcNo() << "] " << "alpha at (0,0.015,0) = " << testVal << nl; } } Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_.valid()? " << (alphaInterpPtr_.valid()) << nl; Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_.empty()? " << (alphaInterpPtr_.empty()) << nl; if(testCell != -1){ //if point is inside mesh (of the current processor) Sout << "[" << Pstream::myProcNo() << "] " << "OUTSIDE scope test: " << nl; scalar alphaAtP = alphaPtr_->internalField()[testCell]; //Does the pointer work? Sout << "[" << Pstream::myProcNo() << "] " << "alpha at cellCenter = " << alphaAtP << nl; scalar testVal = alphaInterpPtr_->interpolate(testPoint, testCell); //Does the pointer work? Sout << "[" << Pstream::myProcNo() << "] " << "alpha at (0,0.015,0) = " << testVal << nl; } } (Just so you know: this method is called for each particle several times, but the code crashes for the very first time this method is called.) Code:
template<class CloudType> void Foam::kvaParticleCaptureAndHold<CloudType>::postMove ( parcelType& p, //reference to parcel, e.g.: KinematicParcel<ParcelType> (which extends ParcelType); Where e.g.: ParcelType = particle. const label cellI, //cellID in which the movement took place (movement across a cell border is done in a separate step and thus a separate postMove() call!) const scalar dt, //delta time const point& position0, //position before moving bool& //keepParticle variable ) { Sout << "[" << Pstream::myProcNo() << "] " << "POSTMOVE begin" << nl; //alphaInterpPtr_.clear(); //Line inserted to see if the autoPtr object responds to me //CRASH if uncommented //Sout << "[" << Pstream::myProcNo() << "] " << "alphaItnerPtr_ is cleared." << nl; vector testPoint(0.,0.015,0.); label testCell = this->owner().mesh().findCell(testPoint); Sout << "[" << Pstream::myProcNo() << "] " << "POSTMOVE --> cellI of (0,0.015,0) = " << testCell << nl; Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_.valid()? " << (alphaInterpPtr_.valid()) << nl; Sout << "[" << Pstream::myProcNo() << "] " << "alphaInterpPtr_.empty()? " << (alphaInterpPtr_.empty()) << nl; if(testCell != -1){ //if point is inside mesh (of the current processor) Sout << "[" << Pstream::myProcNo() << "] " << "POSTMOVE scope test: " << nl; scalar alphaAtP = alphaPtr_->internalField()[testCell]; //Does the pointer work? Sout << "[" << Pstream::myProcNo() << "] " << "alpha at cellCenter = " << alphaAtP << nl; scalar testVal = alphaInterpPtr_->interpolate(testPoint, testCell); //Does the pointer work? //CRASH if "alphaInterpPtr_.clear();" above is commented Sout << "[" << Pstream::myProcNo() << "] " << "alpha at (0,0.015,0) = " << testVal << nl; } } |
October 17, 2014, 11:43 |
Kevin van As
Rep Power: 20 |
Solved.
It always works to talk to the teddybear on your desk, or to post something at the forums. For some reason, you always figure out the problem shortly thereafter (even though you had been trying for the past 3 days). I'm not exactly sure what I effectively changed (I started from scratch)... My hypothesis is that this was my problem: Good: Code:
header: const interpolationCellPoint<scalar>* alphaInterpPtr_; C: alphaInterpPtr_ = new interpolationCellPoint<scalar>(*alphaPtr_); Code:
header: autoPtr<interpolationCellPoint<scalar> > alphaInterpPtr_; C: interpolationCellPoint<scalar> alphaInterp(*alphaPtr_); alphaInterpPtr_ = &alphaInterp; Using "&alphaInterp" for the pointer somehow corrupts the pointer as we leave the method 'preEvolve()' (scope)? No idea (I'm new to C; Experienced in Java) whether that's true. Anyone knows the difference (other than the usage of autoPtr; that's not the problem)? |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 21:59 |
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example | sudo | OpenFOAM Running, Solving & CFD | 3 | April 2, 2013 17:27 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 15:06 |
Segmentation Fault | Shawn_A | OpenFOAM Running, Solving & CFD | 6 | October 31, 2011 14:38 |
ParaView segmentation fault only for multiphase | gwierink | OpenFOAM | 9 | March 25, 2010 07:23 |
