November 12, 2014, 14:09 |
Cannot set 0 trapping - error
Rep Power: 15 |
First off I apologize if this is in the wrong section, I wasn't sure which subforum to post this in.
I have OpenFOAM v2.3.0 installed on a RHEL system using the rpm packs for RHEL. This works fine, and I have had it running for a while now. Recently I needed to export the cfd matrices for some matrix solver work, so I ran the Allmake script after setting WM_COMPILE_OPTION=Debug to recompile in debug mode, intending then to use gdb to export the system matrices. However, now whenever I try and run a solver (for example icoFoam), i get an error "Cannot set 0 trapping" from function "Foam::sigWriteNow::sigWriteNow". Did I screw something up somewhere? I really have no idea what this means. Thank you so much for your help! |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
