wmake error: SourceFiles could not be created in user home
Like Tree4Likes
  • 3 Post By anuragm
  • 1 Post By Andrew.Coughtrie
Old   February 20, 2018, 08:17
Default wmake error: SourceFiles could not be created in user home
Jack
JackJohnson is on a distinguished road
Hi all,
I am completing some University work using Bash on Ubuntu on Windows interface.
I am tying to modify the SimpleFoam solver. However, the following error message appears when I execute the wmake command:
/opt/openfoam5/wmake/wmake: line 409: make: command not found
/opt/openfoam5/wmake/wmake: line 412: make: command not found
wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /home/Matt-ts/OpenFOAM/Matt-ts-5.0/applications/simpleFoamDev
Prior to executing this command I have completed the following steps:
1). Copy simpleFoam solver to $WM_PROJECT_USER_DIR /applications
2). Rename the simpleFoam to a new name (which I have named as simpleFoamDev).
3). Rename source code from simpleFoam.C to simpleFoamDev.C
4). Edit files file in the make folder to:
simpleFoamDev.C
EXE = $(FOAM_USER_APPBIN)/simpleFoamDev
5). Return to SimpleFoamDev folder and enter:
wclean
wmake
This is when the error message appears as per above.
I have been following the modification guide which has been alluded to on previous posts:
http://www.cloudpyme.eu/wp-content/u...on4-Slides.pdf
Does anyone know what the issue may be?
JackJohnson is offline   Reply With Quote
Old   February 21, 2018, 08:46
Anurag
anuragm is on a distinguished road
This is the real problem. You are either missing the package "make" or the path to make binary is not included in the variable PATH. First, check if you have make installed
> dpkg -l make
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name             Version       Architecture  Description
ii  make             4.1-6         amd64         utility for directing compilation
> which make
/usr/bin/make
You should get an output as shown above. If not, then you would have to install either the "make" or the "build-essential" packages and make sure that the path to "make" (/usr/bin for Ubuntu) is included in the environment variable PATH
> echo $PATH
/home/user/salome_7.5.1/salome_appli_7.5.1:/usr/lib64/openmpi/bin/:/home/user/bin:/usr/games:/home/user/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
anuragm is offline   Reply With Quote
Old   February 21, 2018, 08:50
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
Possibly make not being installed.
Try running:
which make
If no result then you'll need to install it.
Andy
JackJohnson likes this.
Andrew.Coughtrie is offline   Reply With Quote
Old   February 21, 2018, 09:00
Jack
Thanks anuragm and Andy!
I did not have the make package installed.
Many thanks both!
modified solver, simplefoam, wmake, wmake error, wmake problems
[OpenFOAM.org] wmake problem vville OpenFOAM Installation 1 October 8, 2015 05:01
Wmake as User sven82 OpenFOAM Installation 3 August 14, 2013 03:23
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
CFX 10 User Routine NOT in Fortran Andre CFX 14 August 8, 2006 23:03
UDF with user created surfaces Henry Lee FLUENT 2 March 23, 2006 03:24
