Different dimensions Error !!!
Like Tree1Likes
  • 1 Post By agustinvo
Old   October 16, 2016, 10:35
Question Different dimensions Error !!!
Mohammad Jam is on a distinguished road
Hi
i implemented especial heat transfer Eq. to chtMultiRegionFoam , it compiles correctly But when i run the case it gives this error :
--> FOAM FATAL ERROR:
Different dimensions for =
dimensions : [0 -1 0 1 0 0 0] = [0 1 -2 1 0 0 0]
i have checked all of Eq. Terms dimension and were OK.
Eq. is:
fvm::ddt(rho*cp, q)-fvm::laplacian(K, q)
K= conductivity [0 2 -1 0 0 0 0]
q= heat flux (vector field) [0 1 -1 1 0 0 0]
rho & cp = Non Dimensional terms
any idea?
thanks in advance
Mohammad Jam is offline   Reply With Quote
Old   October 19, 2016, 06:47
Agustín Villa
agustinvo is on a distinguished road
Originally Posted by Mohammad Jam View Post
Hi
Eq. is:
any idea?
thanks in advance
it seems that in your equation you have a term like dT/dt...
let's see
fvm::ddt(rho*cp, q)
[0 0 -1 0 0 0 0] + [0 0 0 0 0 0 0] +[0 1 -1 1 0 0 0] = [0 1 -2 1 0 0 0]
[0 -2 0 0 0 0 0] + [0 2 -1 0 0 0 0] +[0 1 -1 1 0 0 0] = [0 1 -2 1 0 0 0]
Are they the only terms you have in the equation? How do you define the parameters?
vivek05 likes this.
agustinvo is offline   Reply With Quote
Old   October 19, 2016, 16:19
Originally Posted by agustinvo View Post
let's see
fvm::ddt(rho*cp, q)
Hi Agustín,
Thank you for your kind reply,
Yes there was a [0 -1 0 1 0 0 0] term before solving Eq. and i removed it and then problem solved.
regards,
Mohammad
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
