OF templates < >
Like Tree3Likes
  • 3 Post By deepsterblue
Old   December 16, 2014, 13:21
Default OF templates < >
aylalisa is on a distinguished road
Dear Foamers,
I try to decipher following code snippet, representative for advanced usage of templating in OF (e.g. fvcGrad.H):
template<class Type>
    64     tmp
    65     <
    66         GeometricField
    67         <typename outerProduct<vector, Type>::type, fvPatchField, volMesh>
    68     > grad
    69     (
    70         const tmp<GeometricField<Type, fvsPatchField, surfaceMesh> >&
    71     );
Is that a template for a class or a function? I miss the class keyword before classname and see a return type of grad(), therefore I think it's a function template whose return type is wrapped tmp<> due to its size and is of class type GeometricField which again is a templated type, but a class which can be of type:
- outerProduct<vector, Type>::type
- fvPatchField
- volMesh
Whereas I have no glue if that is correct or completely wrong.
I can't understand outerProduct<vector, Type>::type, especially the double colon irritates me.
Could somebody help?
Ayla
aylalisa is offline   Reply With Quote
Old   December 16, 2014, 14:37
Sandeep Menon
deepsterblue will become famous soon enough
Yes, it's a templated function which computes the gradient of a geometric field. The template parameter Type typically refers to a scalar or vector. Now, when you take the gradient of a scalar field, you get a vector field. And when you take the gradient of a vector field, you get a tensor field.
Notice a pattern? This effectively increased the rank of the field by one. That's what the outerProduct operator does - the outer product of a vector (due to the gradient operator) and Type will yield a new type whose rank is increased by one. Since we need to refer to it somehow, we get it using the outerProduct<vector, Type>::type member. When you write it out (the compiler does this automagically for you), it's defined this way:
outerProduct<vector, scalar>::type = vector;
and
outerProduct<vector, vector>::type = tensor;
At the end of it all, the grad function returns a reference-counted geometric field using the tmp<> class, with a higher rank.
aylalisa, meshman and randolph like this.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
[Commercial meshers] ccm26ToFoam --> checkMesh --> too many errors kornickel OpenFOAM Meshing & Mesh Conversion 0 August 16, 2013 04:37
Fluid travels: Zone 1 --> Zone 2 --> Zone 3. How can I modify diffusivity in each??? ANT FLUENT 1 August 1, 2012 07:55
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM Programming & Development 1 February 16, 2011 20:52
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM 0 December 16, 2010 07:08
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 12:46
