Pointer assignment issues
Old   December 18, 2014, 19:13
Default Pointer assignment issues
Stefanie
SprayStef is on a distinguished road
I am having issues with a pointer...
scalar *Bt_ptr; //protected member of a class (MyEvaporation)
//initialization to the NULL pointer in the constructor of the class
void Foam::MyEvaporation::calculate(..)
scalar Bt=10; //really is being calculated iterativly…
Bt_ptr= &Bt;
doesn’t work…
Bt_ptr -> Bt;
doesn’t work…
(this->Bt_ptr) -> Bt;
doesn’t work…
I’m always getting that same error “request for member ‘Bt’ in '*(…)Foam::MyEvaporation::Bt_Ptr, which is of non-class type 'Foam::scalar {aka double}' ”
PLEASE!!!! HELP!!!
Thanks so much!
Stef
SprayStef is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Pointer Initialization SprayStef OpenFOAM Programming & Development 0 December 17, 2014 13:58
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 16:18
Segmentation Fault caused by a pointer floquation OpenFOAM Programming & Development 1 October 17, 2014 11:43
PtrDictionary: pointer with structure (order) of mesh maybee OpenFOAM Programming & Development 0 February 11, 2014 04:27
