References for the VdjModel in settlingFoam?
Old   April 29, 2014, 05:48
Default References for the VdjModel in settlingFoam?
X Meng
mxylondon is on a distinguished road
Hi guys,
Can anyone tell where I may find the reference for the 'general' and 'simple' models for Vdj in solver 'settlingFoam'?
Really appreciate.
Thanks.
mxylondon is offline   Reply With Quote
Old   May 15, 2014, 10:49
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, check the Brennan's and Bohorquez's theses.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   January 6, 2015, 06:26
Jeremy Dudley
bendel_boy is on a distinguished road
The 'simple' model is the Vesilind model.
The 'general' model is the Takacs model.
The standard version of these models publishes coefficients for suspended solids measured in mass units, typically mg/l, sometimes g/l.
settlingFoam uses volumetric fraction, so you need to convert.
volumetric fraction x solids density should be good enough
bendel_boy is offline   Reply With Quote
Old   January 23, 2015, 12:14
X Meng
Thank you so much for above two answers, really helpful!
settlingFoam crash when velocity increase jimbean OpenFOAM Running, Solving & CFD 1 March 26, 2014 03:59
How to add Exner equation in settlingFoam jimbean OpenFOAM Running, Solving & CFD 1 October 6, 2013 09:59
Unrealistic pressure drop in settlingFoam jochemvandenbosch OpenFOAM Running, Solving & CFD 1 February 2, 2012 04:56
transportProperties settlingFoam jochemvandenbosch OpenFOAM Running, Solving & CFD 3 December 23, 2011 07:44
Diffrence in SettlingFoam 1.5 & 1.6 pramodopen4foam OpenFOAM 0 November 6, 2009 05:15
