moving Body in different directions with topological changes of the mesh |
January 27, 2015, 15:12 |
Mathi
Rep Power: 11 |
Hello foamers,
I'm new to OpenFOAM and using foam-extended-3.1. I want to adapt the tutorial "tutorials / incompressible / icoDyMFoam / movingConeTopo" in the way that a body is moved in x- and y-direction and for each each direction separate movingBodyTopoFvMeshCoeffs defined in the dynamicMeshDict. I considered modifying the file movingBodyTopoFvMesh.C but I'm not sure what exactly to change. Another idea was to subsequently apply the mesh motion module twice for each direction. Can anybody help? kind regards |
April 13, 2015, 05:55 |
Mathi
Rep Power: 11 |
maybe some more information about the problem could be helpful. The case is very simple. Just a structured rectangular mesh. The pictures simpleTopo1.jpg and simpleTopo2.jpg show the motion in vertical direction. The pictures simpleTopoHoriz1.jpg and simpleTopoHoriz2.jpg the direction in horizontal direction. the two motions individual is working and simple. But now I want to move the lower boundary and the right boundary simultanously. This does not work. my blockMeshDict: https://dl.dropboxusercontent.com/u/.../blockMeshDict my dynamicMeshDict: https://dl.dropboxusercontent.com/u/...ynamicMeshDict my meshModifiers: https://dl.dropboxusercontent.com/u/.../meshModifiers my setBatch-file to define the moving faces: https://dl.dropboxusercontent.com/u/77291489/setBatch Maybe the front and backFaces have to be defined differently? |
October 23, 2015, 09:47 |
Tian Tang
Hi!
I am having the same interest of moving the mesh both in x and y direction. I wonder have you figured out the solution? regards, Tian |
March 2, 2016, 05:30 |
#4 | |
Best |
April 23, 2017, 10:34 |
Rep Power: 9 |
Hi guys, can anyone solve the question?
icodymfoam, mesh motion, moving body, topological changes |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Trying to set up Moving Mesh Problem | dreamchaser | CFX | 5 | December 15, 2014 00:07 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Moving Mesh Run problem - Scientific Linux | G. SE | Siemens | 2 | May 7, 2008 07:15 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
