April 4, 2024, 06:32 |
Foam Serious Error while running solver
#1 | |
Hamed Hoorijani
Rep Power: 7 |
Hi everyone,
I am receiving errors regarding two volScalarFields while running my own solver. It's strange to me that only these two variables are causing errors, considering I have defined and worked with other variables in the code without any issues during solver execution. Additionally, I should mention that the solver compiles without any errors or warnings. It's a coupling solver with LIGGGHTS (CFD-DEM), but I'm encountering this error prior to the coupling initiation at each CFD time-step. I am confused why I am getting error just for these two variables, I would appreciate it if anyone can help me. Error: Quote:
volScalarField cellQj ( IOobject ( "cellQj", mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar(dimPower, Zero) ); volScalarField Qaj ( IOobject ( "Qaj", mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar(dimPower, Zero) ); Code:
imensionedScalar tempValue = sqrt(coilElectricalResis/(relParticleMagPer* particleElectricalResis)); dimensionedScalar elecEfficiency = 1/(1 + (Di/Do) * tempValue); forAll(emfVec,celli) { Qaj[celli] = (pow(mag(emfVec[celli]),2)/particleElectricalResis.value())+ SMALL; } cellQj= Qaj/(elecEfficiency * thermalEfficiency); runTime.write(); |
April 16, 2024, 09:56 |
Vinayak Ramachandran
Rep Power: 2 |
Hello Hamedhoorijani,
Not sure this will help, but in your definition of the fields one line seems to be missing; the mesh.time().timeName() parameter inside the IOobject. As per the coding guidelines (https://develop.openfoam.com/Develop...terns/registry) new field definition format is as follows: fieldPtr = new volScalarField ( IOobject ( objectName, mesh.time().timeName(), mesh.thisDb(), IOobject::NO_READ, IOobject::NO_WRITE // implicit: IOobject::REGISTER ), mesh, dimensionedScalar(dimless, Zero) // implicit: calculatedType() ); |
April 16, 2024, 11:04 |
#3 | |
Mark Olesen
Rep Power: 40 |
Good answer, BTW. |
April 17, 2024, 04:23 |
Hamed Hoorijani
Rep Power: 7 |
Dear Vinayak and Mark,
Thank you for your reply. Overlooking those lines was indeed the cause of errors that I was getting. It is solved now. |
coding, openfoam 8, programming |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
