the global index for cells and facess in parallel computation
Like Tree34Likes
Old   October 22, 2015, 11:24
Default the global index for cells and facess in parallel computation
openfoammaofnepo is on a distinguished road
When the parallel computations are conducted with OpenFOAM, the domain will be decomposed into several parts based on the number of the processors. So the following looping and the index "celli" will only for the cells or faces for the local processor:
const volVectorField& cellcentre = mesh.C();
forAll(cellcentre,celli)
  X[celli] = cellcentre[celli][0];
  Y[celli] = cellcentre[celli][1];
  Z[celli] = cellcentre[celli][2];
I am interested to know if there is a chance to know the index of the cell and faces before the demain is decomposed (as listed in constant/polyMesh/faces), in the above lines codes (when parallel computations are conducted). THank you in advance
openfoammaofnepo is offline   Reply With Quote
Old   October 31, 2015, 10:25
Retired Super Moderator
Bruno Santos
Hi OFFO,
This is one of those situations that reaaaaally depends on what is your final objective.
Because from your original description, the solution is pretty simple:
  1. Create a utility that creates a field with the ID of each cell. Pretty much simply copy the source code folder for "writeCellCentres":
    run
    cd ..
    cp -r $FOAM_UTILITIES/postProcessing/miscellaneous/writeCellCentres writeCellIDs
  2. Adapt the source code to create the field with the cell IDs.
  3. Then in your custom solver, load the field that has the cell IDs.
You can do something similar for the faces.
But like I wrote above, it might depend on what is your actual objective.
Best regards,
Bruno
gridley2, Behradskn and yueyun like this.
Old   October 31, 2015, 10:44
Thank you so much, Bruno.
My objective is:
when I run the parallel computations, all the cells and faces will be looped with their indices just in the local processor, not in the global indices (before it was decomposed). Now I would like to get the global indices within the looping in the parallel computations. Is there any method to do that? Thank you.
Originally Posted by wyldckat View Post
Hi OFFO,
    run
    cd ..
Best regards,
Bruno
Old   October 31, 2015, 11:00
Bruno Santos
Quick answer: Like I wrote above, the idea is that you will need to create a field with the cell IDs with another utility, before decomposing.
When you run decomposePar, the field will be automatically decomposed.
Then in your solver, you need to load the field, like you do any other field, like "U" and "p".
And then, instead of looking for the "cellcentre[celli]", you look for:
originalID = cellID[celli];
This will give you the original cell ID.
C. Okubo and JamesCC like this.
Old   October 31, 2015, 11:03
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
You can read cellProcAddresing arrays from processor0 ... processorN folders
see example below
List<List<label> > processCellToGlobalAddr_;
List<label> globalCellToProcessAddr_;
    if (Pstream::parRun())
	processCellToGlobalAddr_.resize
	    Pstream::nProcs()
	//read local cell addressing
	labelIOList localCellProcAddr
	    IOobject
		"cellProcAddressing",
		localMesh.facesInstance(),
		localMesh.meshSubDir,
		localMesh,
		IOobject::MUST_READ,
		IOobject::NO_WRITE
	processCellToGlobalAddr_[Pstream::myProcNo()] = localCellProcAddr;
	//send local cell addressing to master process
	if (Pstream::master())
	    for (label jSlave=Pstream::firstSlave(); jSlave<=Pstream::lastSlave(); jSlave++)
		IPstream fromSlave(Pstream::scheduled, jSlave);
		label nSlaveCells = 0;
		fromSlave >> nSlaveCells;
		processCellToGlobalAddr_[jSlave].resize(nSlaveCells);
		labelList& slaveCellProcAddr = processCellToGlobalAddr_[jSlave];
		forAll(slaveCellProcAddr, iCell)
		    fromSlave >> slaveCellProcAddr[iCell];
	else
	    OPstream toMaster (Pstream::scheduled, Pstream::masterNo());
	    toMaster << localCellProcAddr.size();
	    forAll(localCellProcAddr, iCell)
		toMaster << localCellProcAddr[iCell];
	//redistribute cell addressing to slave processes
		OPstream toSlave (Pstream::scheduled, jSlave);
		forAll(processCellToGlobalAddr_, iProcess)
		    const labelList& thisProcessAddr = processCellToGlobalAddr_[iProcess];
		    const label nCells = thisProcessAddr.size();
		    toSlave << nCells;
		    forAll(thisProcessAddr, jCell)
			toSlave << thisProcessAddr[jCell];
	else
	    IPstream fromMaster(Pstream::scheduled, Pstream::masterNo());
		label nCells = 0;
		fromMaster >> nCells;
		thisProcessAddr.resize(nCells);
		    fromMaster >> thisProcessAddr[jCell];
	forAll(processCellToGlobalAddr_, jProc)
	    const labelList& jProcessAddr = processCellToGlobalAddr_[jProc];
	    forAll(jProcessAddr, iCell)
		label iGlobalCell = jProcessAddr[iCell];
		globalCellToProcessAddr_[iGlobalCell] = iCell;
mkraposhin is offline   Reply With Quote
Old   October 31, 2015, 16:18
Bruno, Thank you for your reply. I think your idea works. This is very clever method!
Old   October 31, 2015, 16:19
Hello mkraposhin,
Thank you so much for your help. I will try your method for my case. This is also very clever approach!
see example below
	    Pstream::nProcs()
	    IOobject
		localMesh,
		IOobject::NO_WRITE
	else
		    toSlave << nCells;
	else
		label nCells = 0;
Old   October 31, 2015, 17:23
Dear Mkraposhin,
In the following lines, if I need to build the relation for bot local cell and face for their global ones, how can I add the face related in the following:
    else
In the normal MPI, we can have the different labels for MPI sending and receiving for cells and faces. But here I do not know use the label to distinguish the data communications for face and cell. Thank you so much if you could have me some hints. Thank you so much.
see example below
	    Pstream::nProcs()
	    IOobject
		localMesh,
		IOobject::NO_WRITE
	else
		    toSlave << nCells;
	else
		label nCells = 0;
Old   November 1, 2015, 06:34
mkraposhin's Avatar
Matvey Kraposhin
Hi, i'm not sure that i understand your question right, but i will try to give more explanation on the code, that i posted above.
For each MPI process (or processor) you can read addressing arrays, which maps local process indexation of primitives into global indexation of primitives. This arrays are located in folder processj/constant/polyMesh in next files
  boundaryProcAddressing
  cellProcAddressing
  faceProcAddressing
  pointProcAddressing
  • boundaryProcAddresing - each element contains global index of patch that is present on current process, for "processor" boundaries this index is -1. Size of this array is equal to number of patches in global mesh plus number of "processor" patches in current processorj folder or processor.
  • cellProcAddressing - each element contains global index of given local process cell. Size of this array is equal to number of cells in current processor
  • faceProcAddressing - each element contains global index of given local process face. Size of this array is equal to number of face in current processor
  • pointProcAddressing - each element contains global index of given local process point. Size of this array is equal to number of points in current processor
You can read this arrays in each MPI process with the code similar to next
	    IOobject
		mesh.facesInstance(),
		mesh.meshSubDir,
		mesh,
		IOobject::NO_WRITE
or for faces
	labelIOList localFaceProcAddr
	    IOobject
		"faceProcAddressing",
		mesh.meshSubDir,
		mesh,
		IOobject::NO_WRITE
then you can store this addresing arrays in another arrays
Variable Pstream::myProcNo() contains id of process. In master process it's value will be 0, in process 1 it's value will be 1 and so on.
At this point array processCellToGlobalAddr_ contains information only about adressing of current process, adressing of other processes is invsible. That's why at next step step you need to redistribute this information across other processes. The idea is simple:
1) send addresing information from all processes to master process (with id #0)
2) send gather infromation from master process to other processes
	else
		    toSlave << nCells;
	else
		label nCells = 0;
At the last step we may need to create reverse addressing - from global cell id to local process cell id (or face id, or point id):
Old   November 1, 2015, 10:07
Dear Matvey,
Thank you so much for your detailed explanation. This is very helpful. If I would like to collect and send the data for both cells and faces in the following codes:
	else
The above is only for cell related information. How to do add the face information sending and gathering based on the above code? I do not know how to distinguish the different informaiton for MPI calling. In MPI, we always use an integer TAG to label the sent and gathered information. But I do not know how to realize it here. Any hints?
Or in other words, when we have multiple packages of data, how to do the sending and gathering in Openfing parallelizations here?
cheer,
OFFO
Old   November 1, 2015, 13:10
mkraposhin's Avatar
Matvey Kraposhin
In OpenFOAM synchronization between processes can be done in many ways:
1) With the usage of MPI standard API - just include "mpi.h" and do what you want to do
2) With IPstream and OPstream class:
2a) with overloaded stream operators "<<" and ">>"
2b) with static functions IPstream::read and OPstream::write
3) reduce and scatter operations - Foam::reduce(...) and Foam::scatter(...) static functions
In the example posted above, i used method 2a) - i don't need to care how data is marked, i only need to remember which data comes first. For example, if i want to send cellProcAddresing and faceProcAddressing array to master process, i must create OPstream class at each slave process. Then i will use it to send data to master process with "<<" operator:
if ( ! Pstream::master() )
    //send size of cellProcAddr to master
    toMaster << cellProcAddr.size();
    //send size of faceProcAddr to master
    toMaster << faceProcAddr.size();
    //send arrays to master
    toMaster << cellProcAddr;
    toMaster << faceProcAddr;
Now, as data was sent to master process, i need to read it in master process in the same order, as i do when i performed 'send' operation before
if ( Pstream::master() )
    //read data from each slaves
        //read number of cells in slave process
        //read number of faces in slave process
        label nSlaveFaces = 0;
        fromSlave >> nSlaveFaces;
        //create storage and read cellProcAddr from slave
        labelList slaveCellProcAddr (nSlaveCells);
        fromSlave >> slaveCellProcAddr;
        //create storage and read faceProcAddr from slave
        labelList slaveFaceProcAddr (nSlaveFaces);
        fromSlave >> slaveFaceProcAddr;
That'all. The only rule - you must read data in recieving process in the same order as it sended in sending process
Old   November 1, 2015, 13:19
Dear Matvey,
Thank you so much! This is clear for me now. Your explanations are very good!
OFFO
Old   November 1, 2015, 14:09
Dear Matvey,
Please allow me to ask one more question:
if I do the following:
Then I can use all the MPI functions which is not related to the OpenFOAM class? Is that right?
Old   November 1, 2015, 14:20
mkraposhin's Avatar
Matvey Kraposhin
Dear Matvey,
Yes, but i think that it would be better to use OpenFOAM's API
Old   November 2, 2015, 04:31
Dear Matvey,
I have modified your code to send and receive the information for face and cell. If you could help to have a look, I would really appreciate it. Thank you.
List<List<label> > processFaceToGlobalAddr_;
List<label> globalFaceToProcessAddr_;
        Pstream::nProcs()
    processFaceToGlobalAddr_.resize
        Pstream::nProcs()
        IOobject
        localMesh,
        IOobject::NO_WRITE
    //read local face addressing
        IOobject
            localMesh,
            IOobject::NO_WRITE
    processFaceToGlobalAddr_[Pstream::myProcNo()] = localFaceProcAddr;
    //send local cell and face addressing to master process
    if (Pstream::master()) // if this is rank=0 processor
            // the cell information
            // the face information
            processFaceToGlobalAddr_[jSlave].resize(nSlaveFaces);
            labelList& slaveFaceProcAddr = processFaceToGlobalAddr_[jSlave];
            forAll(slaveFaceProcAddr, iFace)
                fromSlave >> slaveFaceProcAddr[iFace];
    else // if this is non-rank processor
        // cell information
        // face information
        toMaster << localFaceProcAddr.size();
        forAll(localFaceProcAddr, iFace)
            toMaster << localFaceProcAddr[iFace];
    //redistribute cell and face addressing to slave processes
            // cell information
            toSlave << nCells;
            // face informaiton
            forAll(processFaceToGlobalAddr_, iProcess)
                const labelList& thisProcessAddr = processFaceToGlobalAddr_[iProcess];
                const label nFaces = thisProcessAddr.size();
                toSlave << nFaces;
                forAll(thisProcessAddr, jFace)
                    toSlave << thisProcessAddr[jFace];
    else
        // cell information
        label nCells = 0;
        // face information
            label nFaces = 0;
            fromMaster >> nFaces;
            thisProcessAddr.resize(nFaces);
                fromMaster >> thisProcessAddr[jFace];
    // Set the relation between local and global cell indices
    forAll(processFaceToGlobalAddr_, jProc)
        const labelList& jProcessAddr = processFaceToGlobalAddr_[jProc];
        forAll(jProcessAddr, iFace)
            label iGlobalFace = jProcessAddr[iFace];
            globalFaceToProcessAddr_[iGlobalFace] = iFace;
kaanm likes this.
Old   November 2, 2015, 04:39
Dear Matvey,
How did you define the "localmesh" in the following:
        IOobject
            localMesh,
            IOobject::NO_WRITE
Thank you. When I compiled, I have the error information:
CFD_Cell_Local2Glob.H(27): error: identifier "localMesh" is undefined
Old   November 2, 2015, 04:45
mkraposhin's Avatar
Matvey Kraposhin
localMesh is simply mesh in standard OpenFOAM solver.
Also, according to OpenFOAM coding style, you must erase underscores "_" at the end of variables
In my example this variables were protected members of class, but in your case (if i understand it right) this variables are used as global variables of main(...) procedure.
Behradskn likes this.
Old   November 2, 2015, 05:00
Hi Matvey,
compilation is successful now. Thank you.
Old   November 2, 2015, 05:11
mkraposhin's Avatar
Matvey Kraposhin
If you want to check that everything works, you can do it by dumping arrays to files (OFstream class). If all files from all processors are the same, then your program operates like you expected
Old   November 2, 2015, 05:17
Thank you so much. In openFOAM, how can I output the array to a file? I always try to print it out on the screen, but this does not look good when the data is very large. Thank you.
