Cell Faces: Determining orientation?
Old   September 2, 2011, 11:22
Default Cell Faces: Determining orientation?
Robert Maier
robertmaier9 is on a distinguished road
Hi All,
A little background:
I'm working on a project concerned with the heat transfer across the interface of a multiphase flow using VOF. I am using an adapted version of interFoam. When you have a cell on the interface of two fluids with different heat transfer coeeficients then 0 < alpha < 1. Depending on the angle of the interface you might expect an arithmetic or a harmonic mean of the two to get the overall heat transfer coefficient of the two. Sometimes it's in between both methods. This model tries address this using alpha and the angle of the interface to get a more accurate representation of the heat transfer coefficient, k.
My question:
I would like to calculate for k (heat transfer coefficient) on the faces, but it is critical to know whether the face is horizontal or vertical as the angle of the interface in relation to the direction of heat flow is important. Is there a way to determine the orrientation of a face, i.e. is it horizontal or vertical?
Thanks!
Robert
robertmaier9 is offline   Reply With Quote
Old   September 2, 2011, 11:49
Robert Maier
Nevermind. problem solved!
Old   March 17, 2015, 12:24
Olabanji
banji is on a distinguished road
To determine if a face is aligned vertically or horizontally, you can also follow these instructions:
//Find the surface normal vector for each face and get its internal field
 Field<vector> list = mesh.Sf().internalField();
//iterate through all elements of the list, using 'iter', say, and
//determine the sign of the x-component.
//If the x component > 0, it is vertical, else it is horizontal:
forAll (list, iter)
  if (list[iter].x() > 0)
     Info<< "it is vertical" << endl;
  else
      Info<< "it is horizontal" << endl;
Cheers!
banji is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
