double derivative with respect to time
Old   March 17, 2015, 12:33
Default double derivative with respect to time
Muhammad Usman
13msmemusman is on a distinguished road
Hye i am new user of openFoam i need to calculate double derivative with respect to time of a scalar.
i have a scalar CoMx
i tried to find its double derivative by
scalar DDTCoMx = d2dt2(CoMx);
but i got error
error: ‘d2dt2’ was not declared in this scope
please help me... is there any need to add some header file explaining d2dt2???? if yes then where this header file lies and how to add it in make/options???
13msmemusman is offline   Reply With Quote
Old   March 18, 2015, 08:00
ali alkebsi
kebsiali is on a distinguished road
hi
the d2dt2 is defined within fvm, fvc,.........etc.
to call it you should write
fvc::d2dt2(CoMx) if you want to calculate ( which i think is your case)
fvm:d2dt2(CoMx) in case you want to generate the coefficient matrix to solve an equation
try this and tell me if it works or not.
kebsiali is offline   Reply With Quote
Old   March 18, 2015, 10:22
Post
Muhammad Usman
There is still an error sir
myInterFoamDDT.C: In function ‘int main(int, char**)’:
myInterFoamDDT.C:121:34: error: no matching function for call to ‘d2dt2(Foam::scalar&)’
scalar DDTCoMx = fvc::d2dt2 (CoMx);
myInterFoamDDT.C:121:34: note: candidates are:
In file included from /opt/openfoam231/src/finiteVolume/lnInclude/fvcD2dt2.H:74:0,
from /opt/openfoam231/src/finiteVolume/lnInclude/fvc.H:46,
from /opt/openfoam231/src/finiteVolume/lnInclude/fvCFD.H:8,
from myInterFoamDDT.C:40:
/opt/openfoam231/src/finiteVolume/lnInclude/fvcD2dt2.C:44:1: note: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::d2dt2(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
d2dt2
/opt/openfoam231/src/finiteVolume/lnInclude/fvcD2dt2.C:44:1: note: template argument deduction/substitution failed:
myInterFoamDDT.C:121:34: note: mismatched types ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’ and ‘Foam::scalar {aka double}’
/opt/openfoam231/src/finiteVolume/lnInclude/fvcD2dt2.C:59:1: note: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::d2dt2(const volScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
d2dt2
/opt/openfoam231/src/finiteVolume/lnInclude/fvcD2dt2.C:59:1: note: template argument deduction/substitution failed:
myInterFoamDDT.C:121:34: note: cannot convert ‘CoMx’ (type ‘Foam::scalar {aka double}’) to type ‘const volScalarField& {aka const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&}’
myInterFoamDDT.C:121:8: warning: unused variable ‘DDTCoMx’ [-Wunused-variable]
In file included from myInterFoamDDT.C:61:0:
/opt/openfoam231/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
scalar maxDeltaT =
Old   March 18, 2015, 10:51
ali alkebsi
is CoMx a volScalarField?
could you specify how you define CoMx
The code is searching for a version of d2dt2 that matches the type of your CoMx ( I think) but couldn't find one.
Old   March 18, 2015, 11:06
Muhammad Usman
sir here is code i have got center of mass and indivisual components of center of mass i want to get its time derivatives
CoM = sum(rho*mesh.V()*mesh.C().dimensionedInternalField ())/sum(rho*mesh.V());
Info << "Center of Mass " << CoM.dimensions() << " = " << CoM << nl << endl;
scalar CoMx = CoM.value().x();
Info << "Center of Mass x component = " << CoMx << nl << endl;
scalar CoMy = CoM.value().y();
Info << "Center of Mass y component = " << CoMy << nl << endl;
scalar CoMz = CoM.value().z();
Info << "Center of Mass z component = " << CoMz << nl << endl;
and for time derivative i used
scalar DDTCoMx = fvm::d2dt2 (CoMx);
but got error
Old   March 18, 2015, 11:08
Muhammad Usman
i defined CoMx as scalar and got values but when i tried d2dt2 could not succeed
Old   March 18, 2015, 11:18
ali alkebsi
Could you explain your case a little bit more???
what is it you are trying to model here?
Old   March 18, 2015, 11:25
Post
Muhammad Usman
i and just trying to calculate center of mass of fluid when fluid moves in damBreak tutorial and then find acceleration of center of mass. acceleration in x y and z direction.
Old   March 18, 2015, 11:29
ali alkebsi
well the function called d2dt2 is not appropriate in this case my dear friend.
This function is used to discretize and not to calculate derivatives.
You should search for a utility that would do your task; i dont know if one exists or not.
but what you can do is simply
a=(Vnew-Vold)/dt
where V is done in the same manner
Old   March 18, 2015, 11:53
Post
Muhammad Usman
ohhh sir it means i will have to apply some numerical method to calculate derivative????
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 06:41
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
