cyclic BC - modify boundary face values
Old   May 4, 2015, 16:50
Default cyclic BC - modify boundary face values
Luca
marluc is on a distinguished road
Dear All,
consider a straight duct with inlet and outlet defined as being cyclic patches.
Inside of my own solver I am solving for a scalar transport equation for, say phi. I also define another volScalarField, say phi1, which is not solved but it is derived from the values of phi:
forAll(mesh.cells(),cellI)
phi1[cellI] =
    phi[cellI] + (B * mesh.C().internalField()[cellI]) + C
where B and C can be here assumed as constant scalar values.
Moreover I modify the boundary values of phi1 at the inlet and outlet patch faces as follows:
const fvPatch& currPatchInlet = mesh.boundaryField()[patchInlet]
forAll(currPatchInlet,faceI)
    phi1.boundaryField()[patchInlet][faceI] = phi.boundaryField()[patchID][faceI] + C
const fvPatch& currPatchOutlet = mesh.boundaryField()[patchOutlet]
forAll(currPatchOutlet,faceI)
    phi1.boundaryField()[patchOutlet][faceI] = phi.boundaryField()[patchOutlet][faceI] + C
If I loop over the faces and print the resulting values on the stdout I obtain the expected value but if I check the results in ParaView or if I run a patchAverage on the inlet and outlet patches at the end of a simulation, I obtain the same values on both patches.
Can someone explain me why? Is this related to the cyclic BC or am I missing something?
I hope my question is clear enough to get an answer.
Thank you in advance,
Luca
marluc is offline   Reply With Quote
cyclic bc, face values
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
Radiation interface hinca CFX 15 January 26, 2014 17:11
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
