gdbOF question.. b (or break) fvScalarMatrix.C:144
Old   August 1, 2015, 10:53
Default Solved _ gdbOF question.. b (or break) fvScalarMatrix.C:144
Seokwon Whang
hswzzz is on a distinguished road
Dear Foamer,
I recently read 'gdbOF debugger document' and tried to follow its example, Scalar Transport Test.
(http://openfoamwiki.net/index.php/Contrib_gdbOF)
# .. run the solver in debug mode ($ gdb scalarTransportFoam) >> it works
GNU gdb (GDB) Fedora 7.6.50.20130731-16.fc20
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
Reading symbols from /home/whang/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/bin/scalarTransportFoam...done.
[/FONT]
# when I try to set the break point in the fvScalarMatrix.C:144...>> it does not work
(gdb) b
backtrace bookmark break break-range bt
(gdb) break fvScalarMatrix.C:144
No source file named fvScalarMatrix.C.
Make breakpoint pending on future shared library load? (y or [n])
# if I press 'y' and 'run'...
Make breakpoint pending on future shared library load? (y or [n]) y
Breakpoint 1 (fvScalarMatrix.C:144) pending.
(gdb) run
Starting program: /home/whang/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/bin/scalarTransportFoam
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : /home/whang/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/bin/scalarTransportFoam
Date : Aug 01 2015
Time : 10:47:32
Host : "localhost.localdomain"
PID : 7083
Case : /home/whang/OpenFOAM/whang-2.3.0/run/gdbOFtest/pitzDaily
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field T
Reading field U
Reading transportProperties
Reading diffusivity DT
No finite volume options present
SIMPLE: no convergence criteria found. Calculations will run for 0.1 steps.
Calculating scalar transport
Courant Number mean: 0.01 max: 0.015
Time = 0.005
DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 6.63182e-07, No Iterations 2
Time = 0.01
DILUPBiCG: Solving for T, Initial residual = 0.30043, Final residual = 9.64897e-08, No Iterations 2
Time = 0.015
DILUPBiCG: Solving for T, Initial residual = 0.168124, Final residual = 4.0184e-08, No Iterations 2
Time = 0.02
DILUPBiCG: Solving for T, Initial residual = 0.114029, Final residual = 2.31015e-08, No Iterations 2
Time = 0.025
DILUPBiCG: Solving for T, Initial residual = 0.0847056, Final residual = 1.53854e-08, No Iterations 2
Time = 0.03
DILUPBiCG: Solving for T, Initial residual = 0.0663648, Final residual = 1.10537e-08, No Iterations 2
Time = 0.035
DILUPBiCG: Solving for T, Initial residual = 0.0538484, Final residual = 7.94162e-09, No Iterations 2
Time = 0.04
DILUPBiCG: Solving for T, Initial residual = 0.0447899, Final residual = 1.27641e-07, No Iterations 2
Time = 0.045
DILUPBiCG: Solving for T, Initial residual = 0.0379509, Final residual = 7.66767e-09, No Iterations 2
Time = 0.05
DILUPBiCG: Solving for T, Initial residual = 0.0326205, Final residual = 6.21113e-09, No Iterations 2
Time = 0.055
DILUPBiCG: Solving for T, Initial residual = 0.0283615, Final residual = 5.38958e-09, No Iterations 2
Time = 0.06
DILUPBiCG: Solving for T, Initial residual = 0.0248903, Final residual = 4.79019e-09, No Iterations 2
Time = 0.065
DILUPBiCG: Solving for T, Initial residual = 0.0220149, Final residual = 4.31777e-09, No Iterations 2
Time = 0.07
DILUPBiCG: Solving for T, Initial residual = 0.0198328, Final residual = 3.93061e-09, No Iterations 2
Time = 0.075
DILUPBiCG: Solving for T, Initial residual = 0.0182746, Final residual = 3.60532e-09, No Iterations 2
Time = 0.08
DILUPBiCG: Solving for T, Initial residual = 0.0169228, Final residual = 3.32708e-09, No Iterations 2
Time = 0.085
DILUPBiCG: Solving for T, Initial residual = 0.0157395, Final residual = 3.08573e-09, No Iterations 2
Time = 0.09
DILUPBiCG: Solving for T, Initial residual = 0.0146955, Final residual = 2.87396e-09, No Iterations 2
Time = 0.095
DILUPBiCG: Solving for T, Initial residual = 0.0137678, Final residual = 2.68636e-09, No Iterations 2
Time = 0.1
DILUPBiCG: Solving for T, Initial residual = 0.0129383, Final residual = 2.51879e-09, No Iterations 2
End
[Inferior 1 (process 7083) exited normally]
Missing separate debuginfos, use: debuginfo-install glibc-2.18-19.fc20.x86_64 hwloc-libs-1.7-2.fc20.x86_64 libX11-1.6.1-1.fc20.x86_64 libXNVCtrl-169.12-9.fc20.x86_64 libXau-1.0.8-2.fc20.x86_64 libXext-1.3.2-2.fc20.x86_64 libgcc-4.8.3-7.fc20.x86_64 libpciaccess-0.13.1-4.fc20.x86_64 libstdc++-4.8.3-7.fc20.x86_64 libtool-ltdl-2.4.2-21.fc20.x86_64 libxcb-1.9.1-3.fc20.x86_64 libxml2-2.9.1-2.fc20.x86_64 numactl-libs-2.0.9-1.fc20.x86_64 openmpi-1.7.3-1.fc20.x86_64 xz-libs-5.1.2-6alpha.fc20.x86_64 zlib-1.2.8-3.fc20.x86_64
(gdb) ppatchlist
Use "pPatchList <objeto> "
(gdb) ppatchlist T
No symbol "T" in current context.
what is the problem..?
hswzzz is offline   Reply With Quote
Old   August 3, 2015, 07:27
Seokwon Whang
Solved... after installing debugging-info package
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
