Caracteristic length used for Peclet number
Like Tree1Likes
  • 1 Post By alexeym
Old   June 2, 2015, 10:00
Default Caracteristic length used for Peclet number
Laurent DASTUGUE
laurentD is on a distinguished road
Hi foamers,
Does anybody know what is the caracteristic length used when OpenFOAM calculate the Peclet number ?
I don't have access these days to OpenFOAM and i have to answer this question.
Thanks a lot.
Laurent
laurentD is offline   Reply With Quote
Old   June 2, 2015, 10:38
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It seems you have access to the Internet.
https://github.com/OpenFOAM/OpenFOAM...d/Pe/Pe.C#L118
https://github.com/OpenFOAM/OpenFOAM...olation.C#L136
So, Pe is calculated in assumption Sct = 1 and length scale is cell size.
alexeym is offline   Reply With Quote
Old   June 2, 2015, 10:51
Default Sct ?
Laurent DASTUGUE
Hi Alexey,
thank you for the links, and for your answer concerning the length scale.
Just one question : What is Sct ?
Laurent
Old   June 2, 2015, 11:00
Alexey Matveichev
Sct is turbulent Schmidt number (https://en.wikipedia.org/wiki/Schmidt_number). As you can see, in Pe.C everything is divided by viscosity, yet for Peclet one has to divide by diffusivity. If we assume that Sc = 1, we can just divide by viscosity (for turbulent case we have to assume that Sc = 1 and Sct = 1, so nuEff( = nu + nut) == Deff( = nu/Sc + nut/Sct)).
Old   June 3, 2015, 04:56
Laurent DASTUGUE
Ok i understand now.
Is the Peclet number calculated here a massic one ? (Pe=Re*Sc) or a thermic one (Pe=Re*Pr).
If this is a massic one, can i say that Pe = Re, since Sc = 1 ?
Laurent
Old   June 3, 2015, 05:08
Alexey Matveichev
If you assume Pr = Prt (turbulent Prandtl number) = 1, then it becomes "termic" And yes, you can call the value calculated by Pe utility Reynolds number.
Old   June 3, 2015, 05:18
Laurent DASTUGUE
In fact what i want to do is the calculation of the convection coefficient h.
I know that there is a relation between h and the Nusselt number, and i know a relation letting me to have Nusselt, by the use of Re and Pr values.
Since i have the value of Prandtl number easily, knowing the fluid caracteristics, i just need the value of Re to have Nu and to have finally the value of h.
So reading your posts, i understand the following :
using Pe utility, i can do the operation Re = Pe/Pr to have Reynolds number.
Am i right ? Or must i apply some operations on Pe utility results before having the Peclet number value which will let me calculate Re ?
Laurent
Old   June 3, 2015, 07:54
Alexey Matveichev
Short answer: it depends.
Pe field produced by Pe utility is surfaceScalarField and its value is
\text{Pe}_{\text{calculated by Pe utility}} = \frac{Lu}{\nu}
where L is of order of cell size, u is in fact
u = \frac{\vec{u}\times\vec{S}}{|\vec{S}|}
where S is face normal vector with module equal to the surface of the face.
So, in fact Pe is Re.
If you are happy with h as a surfaceScalarField, then yes, you just manipulate result of Pe utility; if, for example, you need convection coefficient as volume field, you need additional steps.
wayne14 likes this.
Old   June 3, 2015, 08:07
Laurent DASTUGUE
thank you very much for your help.
So what we have is : Pe = Pe / Pr, isn't it ?
Why is this utility not called Re ???
Laurent
Old   June 3, 2015, 09:37
Alexey Matveichev
Yes, though not sure if I get the notation right.
I don't know. Due to certain historical reasons?
Old   June 3, 2015, 10:14
Laurent DASTUGUE
Thank you very much Alexey for your time. Have a good day.
Maybe this utility will be called Re in a next future thanks to your explanations ;-)
Laurent
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Stable boundaries marcoymarc CFX 33 March 13, 2013 06:39
