Modified pimpleFoam solver to MRFPimpleFoam solver
Like Tree4Likes
  • 1 Post By hiuluom
  • 1 Post By blais.bruno
  • 2 Post By hiuluom
Old   June 8, 2015, 07:18
Default Modified pimpleFoam solver to MRFPimpleFoam solver
Huynh Phong Thanh
hiuluom is on a distinguished road
Hi everyone,
I know MRFSimpleFoam solver is steady incompressible. But now I would like to simulation MRF zone with unsteady incompressible. Hence, I modified the pimpleFoam solver becoming MRFPimpleFoam. Here code:
MRFPimpleFoam.C
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
Application
    MRFSimpleFoam
Description
    Steady-state solver for incompressible, turbulent flow of non-Newtonian
    fluids with MRF regions.
#include "fvCFD.H"
#include "singlePhaseTransportModel.H"
#include "RASModel.H"
#include "MRFZones.H"
#include "simpleControl.H"
#include "IObasicSourceList.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    MRFZones mrfZones(mesh);
    mrfZones.correctBoundaryVelocity(U);
    simpleControl simple(mesh);
    Info<< "\nStarting time loop\n" << endl;
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // --- Pressure-velocity SIMPLE corrector
            #include "UEqn.H"
            #include "pEqn.H"
        turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
pEqn.H
    p.boundaryField().updateCoeffs();
    volScalarField rAU(1.0/UEqn().A());
    U = rAU*UEqn().H();
    UEqn.clear();
    phi = fvc::interpolate(U, "interpolate(HbyA)") & mesh.Sf();
    mrfZones.relativeFlux(phi);
    adjustPhi(phi, U, p);
    // Non-orthogonal pressure corrector loop
    while (simple.correctNonOrthogonal())
        fvScalarMatrix pEqn
            fvm::laplacian(rAU, p) == fvc::div(phi)
        pEqn.setReference(pRefCell, pRefValue);
        pEqn.solve();
        if (simple.finalNonOrthogonalIter())
            phi -= pEqn.flux();
    #include "continuityErrs.H"
    // Explicitly relax pressure for momentum corrector
    p.relax();
    // Momentum corrector
    U -= rAU*fvc::grad(p);
    U.correctBoundaryConditions();
    sources.correct(U);
uEqn.H
    // Momentum predictor
    tmp<fvVectorMatrix> UEqn
        fvm::div(phi, U)
      + turbulence->divDevReff(U)
        sources(U)
    mrfZones.addCoriolis(UEqn());
    sources.constrain(UEqn());
    UEqn().relax();
    solve(UEqn() == -fvc::grad(p));
After that, I test with mixerVessel2D model in tutorial OpenFOAM. The result was very good
https://onedrive.live.com/redir?resi...hint=folder%2c
When I simulated with 3D model as turbine. I think it is inaccurate. I do not see the vortex after tubine.
https://onedrive.live.com/redir?resi...nt=photo%2cpng
I don't know velocity not change. Could anybody show me my mistake, please?
Thank you so much
raj kumar saini likes this.
hiuluom is offline   Reply With Quote
Old   June 8, 2015, 10:41
Bruno Blais
blais.bruno is on a distinguished road
If you look at the original article proposing the MRF method, by
J. Luo, R. Issa, A. Gosman, Prediction of impeller induced flows in mixing vessels using multiple frames of reference, in: Institution of Chemical
Engineers Symposium Series, Vol. 136.
They mention that this method is not valid for unsteady state. Actually, there are some underlying hypotheses to the MRF method, which make it inappropriate for unsteady simulations.
So it might work in 2D because you converge to a steady state and your unsteady solver becomes a relaxed steady solver. However, it will not be an appropriate approach in 3D.
Why not use sliding mesh (AMI) instead? I know it is slightly more expensive, but still...
granzer likes this.
blais.bruno is offline   Reply With Quote
Old   June 8, 2015, 12:28
Huynh Phong Thanh
Hi Bruno,
Thanks your reply.
The turbine model has AMI sliding mesh. I have already run with MRFSimpleFoam and it's convergence. I would like to run with unsteady because I change the inlet velocity to oscilatingValued instead of fixValued.
Here is formula: u = 2.7 + 1.6(sěn2(pi)t/16).
MRFSimpleFoam only run steady state with simple interpolation that is reason I modified pimpleFoam. How can run MRF simulation with inlet velocity above?
P/s: I do not want to use pimpleDymFoam.
Old   June 8, 2015, 12:50
Dongyue Li
sharonyue is on a distinguished road
Hello!
I dont think MRF can not be applied into unsteady state situations. In OpenFOAM, multi-phase solvers such as interFoam and twoPhaseEulerFoam can use MRF to simulate stirred tanks.
Which version r u using? pimpleFoam2.3.x can handle MRF by itself.
Best,
My OpenFOAM algorithm website: http://dyfluid.com
By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam
We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html
sharonyue is offline   Reply With Quote
Old   June 8, 2015, 21:07
Huynh Phong Thanh
Hi Dongyue,
I am using OF 2.1.1. I can not upgrade 2.3.x because I am running on server.
By the way, can pimpleFoam in 2.3.x version solve MRF? Which can MRF solver run with "oscillatingFixedValue" inlet BCs?
Old   June 10, 2015, 01:35
Huynh Phong Thanh
Dear all,
I show the velocity result MRFSimpleFoam sovler OF 2.1.1 and pimpleFoam solver OF 2.3.0.
The MRFSimple give very good result, but in pimpleFoam does not see the rear vortex of turbine. In pimpleFoam OF 2.3.0, I only added fvoption
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
MRF1
    type            MRFSource;
    active          true;
    selectionMode   cellZone;
    cellZone        fluid_MRF;
    MRFSourceCoeffs
        origin      (0 0 0);
        axis        (1 0 0);
        omega       2;
If a model want to run MRF with pimpleFoam solver, is it only add fvOption into system directory?
Thank you so much.
Thanh
Old   June 10, 2015, 02:29
Dongyue Li
Originally Posted by hiuluom View Post
Dear all,
Thank you so much.
Thanh
Oops, maybe Im wrong. Sorry,
I just check the code, in two-phase solver, MRF is embeded into pimple algorithm not by fvOptions but by mrfZone class, so maybe even fvOptions can deal with MRF(for steady-state), but it can not be used for pimpleFoam(transient). I guess.
Also, I checked with u original code MRFpimpleFoam, u make ur Ueqn() to be cleared in time step. This is not rite, u need UEqn to upgrade to solve pEqn 2 or 3 times. This is piso algorithm. Maybe u can merge pimpleFoam+mrfZone class instead of doing modifications on simpleFoam.
I make a MRFPimpleFoam solver based on pimpleFoam and tried on the mixer2D case, looks its rite. If u can upload a case to make a test that will be better.
Old   June 10, 2015, 02:53
Huynh Phong Thanh
Hi sharonyue,
Here is my BCs:
|  \\    /   O peration     | Version:  2.1.0                                 |
/*  Windows port by Symscape (www.symscape.com)                              *\
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.598;
boundaryField
    stator
        type            epsilonWallFunction;
        value           uniform 1;
    rotor
        value           uniform 1;
    symmetry
        value           uniform 10.935;
    inlet
        type            fixedValue;
        value           uniform 0.598;
    outlet
        type            zeroGradient;
    wing1
        value           uniform 1;
    wing2
        value           uniform 1;
    wing3
        value           uniform 1;
    wing4
        value           uniform 1;
    wing5
        value           uniform 1;
    wing6
        value           uniform 1;
    AMI1_fluid_MRF
        type            cyclicAMI;
        value           $internalField;
    AMI2_fluid_MRF
        type            cyclicAMI;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.0055;
boundaryField
    stator
        type            kqRWallFunction;
        value           uniform 1;
    rotor
        value           uniform 1;
    symmetry
        value           uniform 0.135;
    inlet
        type            fixedValue;
        value           uniform 0.0055;
    outlet
        type            zeroGradient;
    wing1
        value           uniform 1;
    wing2
        value           uniform 1;
    wing3
        value           uniform 1;
    wing4
        value           uniform 1;
    wing5
        value           uniform 1;
    wing6
        value           uniform 1;
    AMI1_fluid_MRF
        type            cyclicAMI;
    AMI2_fluid_MRF
        type            cyclicAMI;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
internalField   uniform 0;
boundaryField
    stator
        type            zeroGradient;
    rotor
        type            zeroGradient;
    symmetry
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    wing1
        type            zeroGradient;
    wing2
        type            zeroGradient;
    wing3
        type            zeroGradient;
    wing4
        type            zeroGradient;
    wing5
        type            zeroGradient;
    wing6
        type            zeroGradient;
    AMI1_fluid_MRF
        type            cyclicAMI;
    AMI2_fluid_MRF
        type            cyclicAMI;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (-6.2 0 0);
boundaryField
    stator
        type            fixedValue;
        value           uniform (0 0 0);
    rotor
        type            fixedValue;
    symmetry
        type            fixedValue;
    inlet
        type            fixedValue;
        value           uniform (-6.2 0 0);
    outlet
        type            zeroGradient;
    wing1
        type            fixedValue;
    wing2
        type            fixedValue;
    wing3
        type            fixedValue;
    wing4
        type            fixedValue;
    wing5
        type            fixedValue;
    wing6
        type            fixedValue;
    AMI1_fluid_MRF
        type            cyclicAMI;
    AMI2_fluid_MRF
        type            cyclicAMI;
boundaryDIct:
FoamFile
    version                 2.0;
    format                  ascii;
    class                   polyBoundaryMesh;
    location                "constant/polyMesh";
    object                  boundary;
13
    stator
        type                    wall;
        nFaces                  4352;
        startFace               9025787;
    rotor
        type                    wall;
        nFaces                  5288;
        startFace               9030139;
    symmetry
        type                    wall;
        nFaces                  3676;
        startFace               9035427;
    inlet
        type                    patch;  //Velocity-inlet
        nFaces                  514;
        startFace               9039103;
    outlet
        type                    patch;  //Pressure-outlet
        nFaces                  516;
        startFace               9039617;
    wing1
        type                    wall;
        nFaces                  28424;
        startFace               9040133;
    wing2
        type                    wall;
        nFaces                  28424;
        startFace               9068557;
    wing3
        type                    wall;
        nFaces                  28424;
        startFace               9096981;
    wing4
        type                    wall;
        nFaces                  28424;
        startFace               9125405;
    wing5
        type                    wall;
        nFaces                  28424;
        startFace               9153829;
    wing6
        type                    wall;
        nFaces                  28424;
        startFace               9182253;
    AMI1_fluid_MRF
        type                    cyclicAMI;
        nFaces                  7712;
        startFace               9210677;
        matchTolerance          0.0001;
        neighbourPatch          AMI2_fluid_MRF;
        transform               noOrdering;
    AMI2_fluid_MRF
        type                    cyclicAMI;
        nFaces                  7712;
        startFace               9218389;
        neighbourPatch          AMI1_fluid_MRF;
The first time I have simulated with MRFsimpleFoam OF2.1.1. After that, I would like to simulation with unsteady, so I modified pimpleFoam OF2.1.1 and it did not run. As you said, I install OF 2.3.0 and run pimpleFoam with MRF fvOption. The result pimpleFoam OF 2.3.0 still not good. I don't know what I missed file or BCs.
Old   June 10, 2015, 03:12
Dongyue Li
I updated my post, this solver should be the same with yours, but its based on pimpleFoam. Maybe u can upload your 3D case and make a simple test.
About ur boundaries, its right
Old   June 10, 2015, 03:53
Huynh Phong Thanh
Everthing I post above. resultThe result ran with MRFSimpleFoam solver OF 2.1.1 very good. I would like to run oscilating velocity inlet. Hence, I must modified pimpleFoam OF 2.1.1 can run unsteady but it was not successful. The comparison MRFSimpleFoam and pimpleFoam result I posted at the first.
And now I am trying to simulate with pimpleFoam OF2.3.0. I only add fvoption. The result is not the same MRFSimpleFoam of2.1.1
I show test with mixerVessel pimpleFoam OF2.3.0, the result is good. But big model is not good.
Do you have any idea?
If you need more file, you can tell me.
Old   June 10, 2015, 04:59
Dongyue Li
I test pimpleFoam 2.3.x with fvOptions, looks it can deal with MRF.
Also I test my solver(quite simple one), looks there is no difference. Attached is the comparison. I got this mesh from the propeller, but I make the mesh quite coarse.
I did not see any wrong on your boundary, maybe the impeller is rotating way too slow? or some setup is wrong I did not notice? How big is your mesh? U can upload your case.
Old   June 10, 2015, 05:31
Huynh Phong Thanh
Because the mesh is big I can not upload the file. My model is turbine as the same propeller. I show the checkMesh that you can imagine:
Build  : 2.3.0-f5222ca19ce6
Exec   : checkMesh
Date   : Jun 10 2015
Time   : 16:25:14
Host   : "linuxserver"
PID    : 4211
Case   : /home/dfm/Working/phong-thanh/Case02_MSH-MRFPimpleFoam-of230
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            9226101
    internal faces:   9025787
    cells:            4202604
    faces per cell:   4.34299
    boundary patches: 13
    point zones:      0
    face zones:       3
    cell zones:       2
Overall number of cells of each type:
    hexahedra:     0
    prisms:        1441472
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    2761132
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 3941656 cells to cellSet region0
  <<Writing region 1 with 260948 cells to cellSet region1
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    stator              4352     2297     ok (non-closed singly connected)
    rotor               5288     2813     ok (non-closed singly connected)
    symmetry            3676     1888     ok (non-closed singly connected)
    inlet               514      283      ok (non-closed singly connected)
    outlet              516      284      ok (non-closed singly connected)
    wing1               28424    14232    ok (non-closed singly connected)
    wing2               28424    14232    ok (non-closed singly connected)
    wing3               28424    14232    ok (non-closed singly connected)
    wing4               28424    14232    ok (non-closed singly connected)
    wing5               28424    14232    ok (non-closed singly connected)
    wing6               28424    14232    ok (non-closed singly connected)
    AMI1_fluid_MRF      7712     4127     ok (non-closed singly connected)
    AMI2_fluid_MRF      7712     4127     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-100 -39.9951 -40) (60 39.971 40)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-5.85408e-17 -4.19816e-18 6.51828e-16) OK.
    Max cell openness = 4.89647e-16 OK.
    Max aspect ratio = 14.5859 OK.
    Minimum face area = 1.07566e-06. Maximum face area = 59.4783.  Face area magnitudes OK.
    Min volume = 5.69289e-10. Max volume = 138.892.  Total volume = 802492.  Cell volumes OK.
    Mesh non-orthogonality Max: 64.5182 average: 19.8814
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.53318 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
MRFzone
zone1
    cellZone    fluid_MRF;
    active      yes;
    // Fixed patches (by default they 'move' with the MRF zone)
    nonRotatingPatches (AMI1_fluid_MRF AMI2_fluid_MRF stator symmetry inlet outlet);
    origin    (0 0 0);
    axis      (1 0 0);
    omega     constant 2;
I sent you the case in attach file.
I would like to see the vortex sam MRFSimpleFoam 2.1.1
Old   June 14, 2015, 21:22
Huynh Phong Thanh
After waiting for a long time, the vortex appeared at the rear with MRFPimpleFoam 2.1.1 and pimpleFoam OF2.3.0. But in the wing MRF zone, I saw cell.
sharonyue and yuanlee2011 like this.
[swak4Foam] Problem using swak4Foam in a modiefied solver bastil OpenFOAM Community Contributions 13 April 18, 2020 15:17
error while running modified pimple solver R_21 OpenFOAM Programming & Development 0 May 28, 2015 06:59
compiling error(s) in a modified twoPhaseEulerFoam solver foamer OpenFOAM 14 June 20, 2014 08:51
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
