Having trouble writing a coupled differential equation in OpenFOAM
Old   December 1, 2015, 07:42
Default Having trouble writing a coupled differential equation in OpenFOAM
Adkar
adkar is on a distinguished road
Is someone willing to help me write this equation in OpenFOAM?
I want to write this coupled differential equation.
// x = x coordinate.
// Ax = partial derivative of A with ONLY x
(1/x)*Laplacian A - (1/(x*x))*Ax = (B)/x
(1/x)*Laplacian B - (1/(x*x))*Bx = -(A)/x
I have two problems here.
1. How do I write the derivative of A and B only with x and not write it as div(B)?
2. How can I multiply 1/x or 1/x*x to the matrix which is the derivative of A and B only with respect to x?
I have to solve this using a steadystate solver without any time derivative like simpleFoam.
Please Help me.
Thank you.
adkar is offline   Reply With Quote
Old   December 1, 2015, 08:57
Michael Prinkey
mprinkey will become famous soon enough
I haven't worked in OpenFOAM for a while, but these are my first shot at them. My apologies if my OpenFOAM syntax is a little rusty.
(1) You would have to take the gradient of A and B and then dot with the x-direction unit vector. Something like: fvc::grad(A) & vector(1,0,0)
(2) fvMesh has a volume vector field C that contains the cell centroids. Again, dot with the x-direction unit vector to get the x component.
I would multiply through by 1/x^2 to avoid division by zero. I do this reflexively.
There is a coupled solver in the openfoam water supply. You could investigate how to make that work if performance is absolutely critical, but honestly, you are better off by building a segregated iterative solver. Start by fixing B, and solving the first equation for A. Then fixing that result for A and solve the second equation for B. And then iterate until convergence.
mprinkey is offline   Reply With Quote
Old   December 2, 2015, 00:37
Adkar
Thank you so much Mr. Prinkey for your reply.
Taking the dot product after computing the gradient is a very good idea.
I will try that. And thanks for letting me know the tutorial case.
I will take a deeper look into it.
basic, equation, syntax error
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 00:31
Wave Action Equation Solver for OpenFOAM chyczewski OpenFOAM Programming & Development 7 September 4, 2013 11:06
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
