Defining fields as functions of space
Old   June 30, 2015, 08:40
Default Defining fields as functions of space
James Shaw
hertzsprung is on a distinguished road
I have some initial conditions that are specified by functions of (x,y,z).
I would like to programmatically define a field whose values are a function of (x,y,z). Can this be done as part of field construction, rather than looping over cells/faces and setting each value individually?
Further, can I set the internal field and boundary values in a straightforward manner?
hertzsprung is offline   Reply With Quote
Old   July 3, 2015, 05:08
chriss85 will become famous soon enough
You need to loop over the cells and manually assign them values. Same for the boundary, you can use a fixedValue BC and assign values to patch faces.
chriss85 is offline   Reply With Quote
Old   July 4, 2015, 09:03
nemo
huyidao is on a distinguished road
Which solver do you use?Maybe you can try the funkysetfields in the swak4foam.
huyidao is offline   Reply With Quote
divergence free of homogeneous isotroy T in real space (By using Rogallo's method) hiter Main CFD Forum 11 January 29, 2014 12:32
Missing fields in reconstructPar flowris OpenFOAM 1 July 9, 2010 02:48
domainIntegrate, dieselFoam and Lagrangian Fields mturcios777 OpenFOAM 0 May 14, 2010 15:16
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
Fields functions in STAR CCM+ tn Siemens 1 February 15, 2006 09:29
