boundaryField() and internalField() While calculating heat flux |
July 13, 2019, 06:44 |
Ümit Yelken
Rep Power: 7 |
Hello my friends,
Im working to calculate heat flux on patch. I need to calculate reynolds number. But because of no slip bc applied on wall i must use internal value of velocity. Do you have any idea? My code block is: forAll(heatFlux.boundaryField(), patchi) { heatFlux.boundaryField()[patchi] = k_mean.boundaryField()[patchi]*((0.024)*pow((rho.boundaryField()[patchi]*mag(U.internalField()[patchi])*(0.15)/nu_mean.boundaryField()[patchi]),0.8))*(0.898/(0.15))*(T.internalField()[patchi]-T.boundaryField()[patchi]); } It is not working. So how can i obtain internal field value? |
July 15, 2019, 10:19 |
Emily
Rep Power: 8 |
To find the internal velocity of a cell adjacent to a patch you can use U.boundaryField()[patchID].internalField()[internalCellID] where 'patchID' is the ID of your patch and 'internalCellID' is the ID of the cell adjacent to the patch face. You will then have to put this in a forAll loop to cycle through all the mesh cells on the patch face. I hope this helps! Emily |
Used Heat Flux instead of tempearture | roshanak878 | OpenFOAM | 1 | August 9, 2023 21:57 |
wallHeatFlux utility for an incompressible case | Mr.Jingles | OpenFOAM Post-Processing | 67 | April 6, 2023 03:25 |
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary | Struggle_Achieve | OpenFOAM Pre-Processing | 2 | December 20, 2017 03:58 |
solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam | maddalena | OpenFOAM Running, Solving & CFD | 43 | January 11, 2011 02:39 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
