Problem declaring PtrList<autoPtr<phaseChangeTwoPhaseMixture> >
Like Tree1Likes
  • 1 Post By zhengzh5
Old   February 17, 2014, 18:43
Default Problem declaring PtrList<autoPtr<phaseChangeTwoPhaseMixture> >
Jace
zhengzh5 is on a distinguished road
Does anyone have experience combining chtMultiRegionFoam with InterPhaseChangeFoam?
Following outlines what I have done so far:
1. replace the source codes within chtMultiRegionFoam/fluid with the source codes from interPhaseChangeFoam
2. change interPhaseChangeFoam.C to solveFluid.C and cleaned up some header and makefile entries
3. In createFluidFields.H I have:
PtrList<volScalarField> p_rghFluid(fluidRegions.size());
PtrList<volVectorField> UFluid(fluidRegions.size());
PtrList<surfaceScalarField> phiFluid(fluidRegions.size());
PtrList<autoPtr<phaseChangeTwoPhaseMixture> > twoPhasePropertiesFluid(fluidRegions.size());
PtrList<volScalarField> rhoFluid(fluidRegions.size());
forAll(fluidRegions, i)
  Info<<"Reading field p_rgh\n" <<endl;
 p_rghFluid.set
    i,
    new volScalarField
     IOobject
      "p_rgh",
      runTime.timeName(),
      fluidRegions[i],
      IOobject::MUST_READ,
      IOobject::AUTO_WRITE
     fluidRegions[i]
//define other fields as needed
4. In setRegionFluidFields.H I have:
fvMesh& mesh = fluidRegions[i];
pimpleControl pimple(mesh);
volScalarField& p_rgh = p_rghFluid[i];
volVectorField& U = UFluid[i];
surfaceScalarField& phi = phiFluid[i];
autoPtr<phaseChangeTwoPhaseMixture> twoPhaseProperties = twoPhasePropertiesFluid[i];
volScalarField& alpha1 = twoPhaseProperties->alpha1();
volScalarField& alpha2 = twoPhaseProperties->alpha2();
const dimensionedScalar rho1 = twoPhaseProperties->rho1();
const dimensionedScalar rho2 = twoPhaseProperties->rho2();
volScalarField& rho = rhoFluid[i];
The problem is, when I compile the code, I get the following error:
In file included from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmp.H:143:0,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/PtrListI.H:29,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/PtrList.H:321,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/List.C:30,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/List.H:259,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/labelList.H:48,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/UPstream.H:43,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/Pstream.H:42,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/parRun.H:35,
                 from /home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from chtMultiRegionInterFoam.C:37:
/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmpI.H: In destructor ‘Foam::tmp<T>::~tmp() [with T = Foam::autoPtr<Foam::phaseChangeTwoPhaseMixture>]’:
./fluid/createFluidFields.H:83:5:   instantiated from here
/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmpI.H:108:9: error: ‘class Foam::autoPtr<Foam::phaseChangeTwoPhaseMixture>’ has no member named ‘okToDelete’
/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmpI.H:115:13: error: ‘class Foam::autoPtr<Foam::phaseChangeTwoPhaseMixture>’ has no member named ‘operator--’
/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmpI.H: In member function ‘T* Foam::tmp<T>::ptr() const [with T = Foam::autoPtr<Foam::phaseChangeTwoPhaseMixture>]’:
/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/PtrListI.H:116:47:   instantiated from ‘Foam::autoPtr<T> Foam::PtrList<T>::set(Foam::label, const Foam::tmp<T>&) [with T = Foam::autoPtr<Foam::phaseChangeTwoPhaseMixture>, Foam::label = int]’
/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmpI.H:159:10: error: ‘class Foam::autoPtr<Foam::phaseChangeTwoPhaseMixture>’ has no member named ‘resetRefCount’
then I thought maybe I'm not supposed to use PtrList and autoPtr together, so I tried:
PtrList<phaseChangeTwoPhaseMixture> twoPhasePropertiesFluid(fluidRegions.size());
and setRegionFluidFields.H
phaseChangeTwoPhaseMixture& twoPhaseProperties = twoPhasePropertiesFluid[i];
instead, but this gives me problem with
interfaceProperties interface(alpha1, U, twoPhaseProperties());
autoPtr<incompressible::turbulenceModel> turbulence
 incompressible::turbulenceModel::New(U, phi, twoPhaseProperties())
because it doesn't recognize the twoPhaseProperties() anymore.
Does anyone have any suggestions related to how I can go about solving this problem. Thanks for your helps in advance!
Regards,
Jace
mizzou likes this.
zhengzh5 is offline   Reply With Quote
Old   August 16, 2015, 17:22
Mahdi
Mahdi2010 is on a distinguished road
Did you already find the solution for this issue?
Mahdi2010 is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
