a bug when correctting the flux in dynamicRefineFvMesh?
Old   January 11, 2016, 04:01
Default a bug when correctting the flux in dynamicRefineFvMesh?
Yu CAO
cctv is on a distinguished road
Hi:
I was confused of the code correcting the flux in the function autoPtr<mapPolyMesh> dynamicRefineFvMesh::refine of the file dynamicRefineFvMesh.C
It is written like this
// Correct the flux for modified/added faces. All the faces which only
// have been renumbered will already have been handled by the mapping.
const labelList& faceMap = map().faceMap();
const labelList& reverseFaceMap = map().reverseFaceMap();
// Storage for any master faces. These will be the original faces
// on the coarse cell that get split into four (or rather the
// master face gets modified and three faces get added from the master)
labelHashSet masterFaces(4*cellsToRefine.size());
forAll(faceMap, faceI)
label oldFaceI = faceMap[faceI];
if (oldFaceI >= 0)
label masterFaceI = reverseFaceMap[oldFaceI];
if (masterFaceI < 0)
FatalErrorIn
"dynamicRefineFvMesh::refine(const labelList&)"
) << "Problem: should not have removed faces"
<< " when refining."
<< nl << "face:" << faceI << abort(FatalError);
else if (masterFaceI != faceI)
masterFaces.insert(masterFaceI);
I am not sure why the size of the masterfaces is 4*cellsToRefine.size(). What is more, I am quite confused about the condition when filling up masterfaces. It is (masterFaceI != faceI), in my view, the masterface refers to faces with the same faceID, and it should be (masterFaceI == faceI). I am not sure if there is anything wrong with my understanding.
when calculating the new internal faces, it is written like this
// Recalculate new internal faces.
for (label faceI = 0; faceI < nInternalFaces(); faceI++)
if (oldFaceI == -1)
// Inflated/appended
phi[faceI] = phiU[faceI];
else if (reverseFaceMap[oldFaceI] != faceI)
// face-from-masterface
I am not sure why it is phi[faceI] = phiU[faceI], I think it should be phi[faceI] = phiU[reverseFaceMap[oldFaceI]]. otherwise, why not use
forAll(phi,faceI)
directly? Does anybody know the reason? Thank.
Yu
cctv is offline   Reply With Quote
Old   January 12, 2016, 04:16
Yu CAO
Well. I think I have found out the reason. Thank you all for your attention.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Udf for moving heat flux in 2D cylindrical geometry devia21 Fluent UDF and Scheme Programming 0 April 20, 2015 00:27
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
