about "thermoType" in reactingTwoPhaseEulerFoam for modelling coal combustion |
May 1, 2017, 12:39 |
Rep Power: 14 |
If we use reactingTwoPhaseEulerFoam to simulate the pulverized coal combustion, we will assume that the solid coal particle phase to be the dispersed phase. Typically the coal pharticle phase is composed of multiple components, i.e. char, volatile and ash. So here since it is assumed to be a fluid, in the openfoam we need to specify the equationOfState, so here what type of EoS should we use for the particle phase? In constant/thermophysicalProperties.particles of reactingTwoPhaseEulerFoam simulations, we have the following: Code:
thermoType { type heRhoThermo; mixture multiComponentMixture; transport const; thermo hConst; equationOfState perfectFluid; specie specie; energy sensibleInternalEnergy; } Thank you in advance! best regards, OFFO |
May 31, 2023, 03:41 |
xinyu
Rep Power: 4 |
Can you share your experience? I also have similar issues
Coal combustion injection properties | semo | FLUENT | 12 | May 16, 2017 19:40 |
Non premixed- Coal combustion | praveen2011 | FLUENT | 3 | November 1, 2016 08:57 |
Problem on EDC model for coal combustion | lei | FLUENT | 4 | September 3, 2015 09:39 |
Coal combustion and ash reaction kinetics | sega | Fluent UDF and Scheme Programming | 0 | January 21, 2010 08:05 |
moisture in coal combustion | Sheng | FLUENT | 3 | June 15, 2003 19:43 |
