remove particle
Like Tree1Likes
  • 1 Post By nimasam
Old   November 14, 2015, 15:44
Default remove particle
Nima Samkhaniani
nimasam is on a distinguished road
im going to implement a function in icoLagrangianFoam, and i use basicKinematicCloud, i want to delete a particle from specific zone in computational domain. for now i can return access to particle and mark it, but i dont know how to remove it.
deleteParticle or move functions are a part of Cloud class, i can not understand how i can access to Cloud.H from basicKinematicCloud object?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 15, 2015, 05:42
Nima Samkhaniani
i continue this post, it can be achieve with following piece of code:
kinematicCloud.deleteParticle(p);
but after it deletes the first particle, it error in second one, the error line is:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam:LListBase::remove(Foam:LListBase::link*) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
in "/home/nimasam/OpenFOAM/nimasam-2.2.0/platforms/linuxGccDPOpt/bin/icoLagrangianFoam"
#5 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Segmentation fault (core dumped)
Old   November 15, 2015, 13:18
Nima Samkhaniani
the problem solved
Old   September 5, 2016, 07:15
Default delete particle
sina
aghsin is on a distinguished road
Hi Nima,
would you please explain how did you managed to solve the problem?
aghsin is offline   Reply With Quote
Old   September 30, 2016, 13:43
Nima Samkhaniani
following syntax:
typedef typename Foam::KinematicParcel<Foam::particle> parcelType ;
forAllIter( basicNewKinematicCloud , kinematicCloud, iter)
    parcelType& p = iter(); //paticle
aghsin likes this.
Old   March 27, 2020, 21:10
ywj
Wenjie Yang
ywj is on a distinguished road
hi, could you please tell me where you write those codes?
ywj is offline   Reply With Quote
Old   March 28, 2020, 19:41
Nima Samkhaniani
you can add it to your Lagrangian solver and recompile the solver
basickinematiccloud, particle
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 13:30
Remove particle in solidParticleFoam shchepan OpenFOAM Programming & Development 8 April 16, 2014 17:29
injection problem Mark New FLUENT 0 August 4, 2013 01:30
forced to sticking of soot particle kmgraju CFX 0 November 27, 2012 09:08
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
