error with new+modified interfaceProperties library
Like Tree1Likes
  • 1 Post By mkraposhin
Old   January 7, 2016, 10:50
Default error with new+modified interfaceProperties library
Andrea Ferrari
Andrea_85 is on a distinguished road
i am trying to modify the interfaceProperties lib. To do this i created a new library (say "myInterfaceProperties"), which, for the moment, looks exactly as the original one. The only difference is that i am trying to pass more fields to the library. I modified the constructors part in interfaceProperties.C as follow (red parts are new)
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::myInterfaceProperties::myInterfaceProperties
    const volScalarField& alpha1,
    const volVectorField& U,
    const volScalarField& DeltaX,
    const volScalarField& DeltaY,
    const IOdictionary& dict
    alpha1_(alpha1),
    U_(U),
    dx_(DeltaX),
    dy_(DeltaY),
Then, i added the declaration of the two new variables in interfaceProperties.H
const volScalarField& alpha1_;
const volVectorField& U_;
const volScalarField& dx_;
const volScalarField& dy_;
DeltaX and DeltaX are defined in the main code as volScalarField.
I called the new library in createField.H as
myInterfaceProperties interface(alpha1, U, DeltaX, DeltaY, twoPhaseProperties);
I have successfully compiled both the new library and the main code but when i try to run the code i get this error just after the library is called
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::myInterfaceProperties::myInterfaceProperties(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&) at ??:?
 at ??:?
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Segmentation fault (core dumped)
Note that i am not even using DeltaX DeltaY, this was just a test to see if the new variables were correctly passed to the new library and it seems they are not.
Any idea about the error?
Andrea
Andrea_85 is offline   Reply With Quote
Old   January 7, 2016, 12:21
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Hi!
Which OF version are you using? OF2.4.0 or less?
Did you pointed your Make/options file to new library, like that:
EXE_INC =
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$myInterfaceProperties/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/fvOptions/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -ltwoPhaseMixture \
    -lmyInterfaceProperties \
    -ltwoPhaseProperties \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lfiniteVolume \
    -lmeshTools \
    -lfvOptions \
    -lsampling
In any way the better practice, is to create your own derived class, which inherits standard OpenFOAM class. In this class you can put anything you want.
mkraposhin is offline   Reply With Quote
Old   January 7, 2016, 12:42
Andrea Ferrari
thanks for your reply. I am using 2.3.1
This is exactly what i have done. I created a new solver and linked to it the new libraries. This is how the Make/option file looks like (again in red the new parts)
EXE_INC = \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/triSurface/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I./myInterfaceProperties/lnInclude \
    -I./myTwoPhaseProperties/lnInclude
EXE_LIBS = \
    -ltwoPhaseMixture \
    -linterfaceProperties \
    -lincompressibleTransportModels \
    -lsampling \
    -lfiniteVolume \
    -lfvOptions \
    -ltriSurface \
    -lmeshTools \
    -lmyTwoPhaseProperties
the "old" libraries are still there because i need both. Btw i got no error during the compilation so i am guessing they are properly linked.
Andrea
Old   January 7, 2016, 12:53
mkraposhin's Avatar
Matvey Kraposhin
Andrea
I think, here is the point of your problem. Your program will work in two cases:
- you will create and will use child class from interfaceProperties
- you will leave only your own version of interfaceProperties
Old   January 7, 2016, 13:08
mkraposhin's Avatar
Matvey Kraposhin
By the way, did you renamed your twoPhaseProperties class?
It looks like a mismatch in data types naming
Old   January 7, 2016, 13:37
Andrea Ferrari
I quickly tried to remove the link i don't need to the old libraries, recompiled but the error is still there. The Make/option file now is
EXE_INC = \
EXE_LIBS = \
    -ltwoPhaseMixture \
    -lsampling \
    -lfiniteVolume \
    -lfvOptions \
    -ltriSurface \
    -lmeshTools \
The "twoPhaseProperties" lib is there for the alphaContactAngle that i need. In myTwoPhaseProperties ive implemented new Bc for another scalarField (levelSet). The lib has a different name and i changed all the names of all the functions inside. It shouldn't be a problem.
Before, I successfully compiled and used the same solver (with both "old" and "new" interfaceProperties and twoPhaseProperties linked to the main program) but without the additional fields (DeltaX and DeltaY) in the new myInterfaceProperties. Now i need to perform extra calculation and i would like to do it inside the library. That's why i am trying to pass the two fields. I think the error is somewhere there. maybe a wrong variable declaration?
anyway thanks for spending your time on it!
Andrea
Old   January 7, 2016, 13:49
mkraposhin's Avatar
Matvey Kraposhin
There is a type conflict somewhere else. My suggestion is to re-use standard OpenFOAM classes:
in .H:
class myInterfaceProperties
: public interfaceProperties
in .C:
    interfaceProperties(alpha1, U, dict)
    dx_(DeltaX),
    dy_(DeltaY),
If you will switch to OF2.3.0 or 2.4.0, i can try to compile and test your, because i think that you are missing something small.
Also, i took part in this thread where this problem was also solved
Adding the Energy Equation to interFoam (OF 2.4.0)
Old   January 8, 2016, 10:57
Andrea Ferrari
after a depth debugging i think i understand (at least) where the error comes from but still i do not know how to fix it. I rewrote the library adding things step by step. Now i am able to corretly pass the two fields DeltaX and DeltaY. The error seems to be generated by another volScalarField i defined inside the library. The variable is named nuGamma_
in myInterfaceProperties.C i added the variable constructor by copy paste nHatf_ from the original interfaceProperties.C
  nuGamma_
        IOobject
            "nuGamma",
            alpha1_.time().timeName(),
            alpha1_.mesh()
        alpha1_.mesh(),
        dimensionedScalar("nuGamma", dimless, 0.0)
in myInterfaceProperties.H i added the variable declaration and the member function
                           Class myInterfaceProperties Declaration
volScalarField nuGamma_;
 // Member Functions
 const volScalarField& nuGamma() const
            return nuGamma_;
I am not using nuGamma, for the moment ive just declared it.
With these lines i got the error in my first post, without these line the code runs with no problem. I really dont see where is the problem.
Old   January 8, 2016, 12:45
mkraposhin's Avatar
Matvey Kraposhin
This problem can be solved easily - check that you are initializing alpha1_ before nuGamma_
If this works, tell me, and i will give explanation later
Old   January 8, 2016, 15:41
Andrea Ferrari
oh...that was really easy...it works
I did not know it was important the initialization order...i learn new things every day...
thank you very much
andrea
Old   January 9, 2016, 03:29
mkraposhin's Avatar
Matvey Kraposhin
Yes, initialization order makes sense.
Sometimes, compiler watches for this - for example, if you declare dx_ and then dy_ in interfaceProperties.H, but initialize dx_ after dy_ in interfaceProperties.C, you will get compiler "warning". This should not generate error in most cases. But it is a good practice to declare and initialize variables in the same order
In your case, you tried to use members of reference to object (volScalarField& alpha1_), which was not initialized.
Reference - is a special type of C++, which must be initialized during it's definition.
In your case, everything, that is between body of constructor " {} " and arguments " : " is treated as the default initialization for members, declared in interfaceProperties.H
lihaoyun likes this.
[Other] Multi species mass transport library [update] novyno OpenFOAM Community Contributions 111 November 9, 2021 23:37
ERROR: unable to find library HJH CFX 6 February 26, 2019 06:52
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 07:17
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
