Cannot compile a solver containing the "gSum" function
Old   February 11, 2016, 03:28
Default Cannot compile a solver containing the "gSum" function
Manuel do Nascimento
MdoNascimento is on a distinguished road
Hello, I was trying to compile a solver which contains the function "gSum". There is an error saying there is no proper function for calling gSum.
Any suggestions?
Thanks
MdoNascimento is offline   Reply With Quote
Old   February 11, 2016, 03:42
akidess's Avatar
Anton Kidess
I suggest you include the relevant code you wrote and the exact error message.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 11, 2016, 03:58
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
gSum works only with basic arrays - Field<T>, List<T> and so on. gSum doesn't work with complex fields, like GeometricField, i.e. volVectorField, surfaceScalarField.
mkraposhin is offline   Reply With Quote
Old   February 11, 2016, 04:55
Sorry!
The line in the code that gives the error message:
sumV = gSum(alpha1*mesh.V());
(solver based on interFoam)
in createfields: const volVectorField& C = mesh.C();
The error message was given in german, that's why I tried to translate it as well as possible:
filename.H: in function "int main(int char**)":
filename.H: error: no proper function for calling gSum(Foam::tmp<Foam:: DimensionedField<double, Foam::volMesh> >)«
readMRFControls.H:26:31: note: candidates are:
/opt/openfoam211/src/OpenFOAM/lnInclude/FieldFunctions.C:490:1: note: template<class Type> Type Foam::gSum(const Foam::UList<T>&)
/opt/openfoam211/src/OpenFOAM/lnInclude/FieldFunctions.C:490:1: note: template<class Type> Type Foam::gSum(const Foam::tmp<Foam::Field<Type> >&)
/opt/openfoam211/src/OpenFOAM/lnInclude/FieldFieldFunctions.C:564:1: note: template<template<class> class Field, class Type> Type Foam::gSum(const Foam::FieldField<Field, Type>&)
/opt/openfoam211/src/OpenFOAM/lnInclude/FieldFieldFunctions.C:564:1: note: template<template<class> class Field, class Type> Type Foam::gSum(const Foam::tmp<Foam::FieldField<Field, Type> >&)
Old   February 11, 2016, 10:08
Problem solved! Had to use
sumC = gSum(C.internalField()*alpha1.internalField()*mesh .V());
instead of
sumC = gSum(C.internalField()*alpha1*mesh.V());
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
function within solver lindstroem OpenFOAM Programming & Development 8 November 30, 2012 11:20
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
