Access processor patches in parallel run
Like Tree4Likes
  • 4 Post By chriss85
Old   February 11, 2016, 10:03
Default Access processor patches in parallel run
mheinz is on a distinguished road
Hello together,
I am currently working with the wallDist functionality to compute the distance of each cell to its nearest wall. After that I want to cut the data regarding some criterions. Everything works fine, when I calculate on one processor. However, when performing a parallel run, I need to access the patches that connect the seperated meshes of each processor. That's where I need help.
Here is some of the code, that needs fixing:
cellDist = wallDist(mesh).y();
const fvPatchList& patches = mesh.boundary();
forAll (patches, iPatch)
    const fvPatch& singlePatch = patches[iPatch];
    forAll (singlePatch, iFace)
        label iFaceCell = singlePatch.faceCell()[iFace];
        cellDist[iFaceCell] = 0.0;
This way, I tried to access all boundary patches (mesh.boundary()), but the "processor patches" are not recognized as such.
I'm thankful for any advice.
Michael
mheinz is offline   Reply With Quote
Old   February 12, 2016, 03:54
chriss85 will become famous soon enough
You can combine lists from separate processors using the following function. This can be used for face positions, areas, field values etc..
template<class Type>
    void combineFields(Field<Type>& field)
        List<Field<Type> > allValues(Pstream::nProcs());
        allValues[Pstream::myProcNo()] = field;
        Pstream::gatherList(allValues);
        Pstream::scatterList(allValues);
        field =
        ListListOps::combine<Field<Type> >
            allValues,
            accessOp<Field<Type> >()
chriss85 is offline   Reply With Quote
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 10:25
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
