incorporate energy equation to DPMFoam
Like Tree1Likes
  • 1 Post By floquation
Old   March 31, 2016, 14:02
Default incorporate energy equation in DPMFoam
Bijan Darbari
bijan darbari is on a distinguished road
Dear all
I,m trying to incorporate Temperature field and the Energy equation in "DPMFoam" solver. So I do these main steps.
1- create "EEqn.H":
fvScalarMatrix EEqn
            fvm::ddt(T)
            + fvm::div(alphaPhic, T)
            - fvm::laplacian(DT, T)
EEqn.relax();
2- add "#include EEqn.H" in "DPMFoam.c",just after pimple loop
3- create temperature field and "DT" in "createFields.H"
IOdictionary transportProperties
    IOobject
        "transportProperties",
        runTime.constant(),
        mesh,
        IOobject::MUST_READ_IF_MODIFIED,
        IOobject::NO_WRITE
word continuousPhaseName
    transportProperties.lookup("continuousPhaseName")
dimensionedScalar DT
    transportProperties.lookup("DT")
Info<< "Reading field T\n" << endl;
volScalarField T
    IOobject
        "T",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
4- rename this solver to "DPMH"
this solver compiled successfully without any error.
but when I try to solve a simple test case, I get this error:
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 19 the label 100
file: /home/bijan/Desktop/mycase1/constant/transportProperties.DT at line 19.
    From function operator>>(Istream&, word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
The solver and test case attached.
DPMH.zip
mycase1.zip
Please kindly guide me.
bijan darbari is offline   Reply With Quote
Old   April 1, 2016, 02:35
floquation's Avatar
Kevin van As
floquation will become famous soon enough
I'm no expert, but given the error message I'd first try the following:
Change (constant/transportProperties)
DT 0.001;
into
DT.air 0.001;
as it is apparently looking for a "word" after "DT", I suspect ".air" must be written there.
bijan darbari likes this.
floquation is offline   Reply With Quote
Old   April 1, 2016, 09:05
Bijan Darbari
Thanks very much floquation.
I used this code and the case run without any problem. so calculate the temperature filed of continuous phase.
DT        DT [0 2 -1 0 0 0 0] 1.42e-7;
the modified solver:
DPMH.zip
but still my modified solver don't calculate the temperature field of particles.
in the following, I'll try to incorporate heat transfer equation to particles cloud.
Old   April 7, 2016, 09:44
Bijan Darbari
Dear all
As I mentioned earlier, I want to solve the heat transfer equation for
lagrangian particles in DPMFoam solver.
Fortunately, it can be done by openfoam standard "basicThermoCloud"
(without considering the colliding effect). Therefore, I do following
step in in my modified solver:
1- in "DPMH.C", I replace:
#ifdef MPPIC
    #include "basicThermoCloud.H"
    #define basicKinematicTypeCloud basicThermoCloud
#else
#endif
2- in "createFields", I add:
Info<< "Constructing kinematicCloud " << kinematicCloudName << endl;
    kinematicCloudName,
    rhoc,
    Uc,
    muc,
    slgThermo,
   g
3- in "make/options", I add:
-I$(LIB_SRC)/thermophysicalModels/properties/liquidProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/liquidMixtureProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/solidProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/solidMixtureProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/thermophysicalFunctions/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/SLGThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \
and
 -lliquidProperties \
    -lliquidMixtureProperties \
    -lsolidProperties \
    -lsolidMixtureProperties \
    -lthermophysicalFunctions \
    -lreactionThermophysicalModels \
    -lSLGThermo \
    -lchemistryModel \
    -lradiationModels \
4- in the the beginning of "DPMH.C", I add:
#include "SLGThermo.H"
and I compile this solver. but I get this error:
In file included from DPMHP.C:68:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:159:5: error: ‘slgThermo’ was not declared in this scope
     slgThermo,
What is the solution??
In the other words, How I can import the thermophysical properties of
continuous phase (K,Cp,...) to "basicThermoCloud" as input parameters
when I use the "constant transport properties" in the Constant Directory??
This solver have been attached.
Old   April 10, 2016, 12:54
Bijan Darbari
I'm looking forward to hear from you soon
Old   December 2, 2016, 20:46
Scram_1 is on a distinguished road
Hey Bijan,
did you find a work-around for solving the energy equation in DPM Foam?
Scram_1 is offline   Reply With Quote
Old   January 12, 2017, 12:06
solti
tri3345 is on a distinguished road
Dear Bijan ,
could you solve the error?, I have a problem same as you, in a simulation I need the temperature of particles in DPMFoam, Can you guide me?
tri3345 is offline   Reply With Quote
Energy equation issue zytra FLUENT 0 October 20, 2014 21:34
Need experience comment on cavitation combine energy equation!!! lehoanganh07 FLUENT 0 September 24, 2014 10:28
Energy equation in OpenFoam nwpukaka OpenFOAM Programming & Development 2 June 24, 2014 02:40
energy equation in rhoCentralFoam nakul OpenFOAM 0 October 10, 2010 15:07
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
