How to continue a paused Simulation case with ctrl+c |
March 14, 2016, 15:30 |
Mohsen
Rep Power: 13 |
I know that we can pause a simulation or runnig case with ctrl+c keys. but I want to know how to continue the rest of simulation? which keys should I use? or should I start from beginning? Thanks |
March 15, 2016, 03:33 |
Rep Power: 10 |
I think for that, you can apply Ctrl+s to stop for a while and press Ctrl+Q to continue.
But if you want to check for instance, paraview at the same time , I recommend you instead of Ctrl+c , open another Terminal and do that |
March 15, 2016, 03:40 |
Anton Kidess
Rep Power: 30 |
Ctrl+S just suspends the terminal output. To suspend the process, you use Ctrl+Z.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
rerun, stop simulation |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
interrupt the simulation, check results, continue simulation | soulsaver | Phoenics | 1 | June 28, 2013 01:15 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 09:32 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Ask for case of SOFC simulation in FLUENT | Bayern | FLUENT | 0 | October 7, 2005 23:00 |
