rotatingWallVelocity normal to wall
Old   June 21, 2012, 06:00
Default rotatingWallVelocity normal to wall
Robert Castilla
rcastilla is on a distinguished road
I am working in a simulation with dynamic mesh. But, previously, I wanted to make the stationary simulation. A wall is rotating, and I wonder if I could use the rotatingWallVelocity. I tried with pimpleFoam, and the results are not correct (very high velocities in some cells, near to the rotating wall). Even with potential Foam, it gives velocity zero (no wall velocity?) around the domain, except on the wall.
I checked the rotatingWallVelocity BC source and I found that:
// Remove the component of Up normal to the wall
// just in case it is not exactly circular
const vectorField n(patch().nf());
vectorField::operator=(Up - n*(n & Up));
Does it mean that only the tangencial wall velocity is considered for the fluid motion? Why? Anyway, I will try to remove this constraint, and I see what happens... but I would like to know the reason of that.
Thanks
Robert
rcastilla is offline   Reply With Quote
Old   June 21, 2012, 15:21
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Originally Posted by rcastilla View Post
vectorField:perator=(Up - n*(n & Up));
Thanks
Robert
I believe that this boundary condition is made for circular boundaries and to act as if it were a no slip no penetration rotating wall, as you described. Because it is a 'wall' no penetration is implied, hence the removal of the face normal component of the velocity. This is a relatively straight forward velocity boundary condition. I doubt that your issues with running it in conjunction with pimpleFoam are related to a bug or something to that nature.
kmooney is offline   Reply With Quote
Old   April 2, 2024, 09:29
S03r3n
S03r3n is on a distinguished road
Thanks
Robert
Did it work to remove the constraint?
Can you share your experience/ results?
Thanks in advance!
S03r3n is offline   Reply With Quote
Old   April 3, 2024, 03:22
Robert Castilla
Thanks in advance!
Hi, S03r3n,
It was long time ago, and I don't remember now the details. But I think that we solved the problem finally, and it was published in the Journal of Fluids Engineering, of the ASME:
Castilla, R., Gamez-Montero, P. J., Raush, G., & Codina, E. (2017). Method for fluid flow simulation of a gerotor pump using OpenFOAM. Journal of Fluids Engineering, 139(11), 111101.
It was used to deform the mesh of a gerotor pump.
Regards
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Wall Normal Temperature Gradient Daniel Tanner FLUENT 6 September 20, 2015 13:10
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 14:35
momentum equation (Normal to wall) kk Main CFD Forum 0 July 2, 2006 23:13
Velocity gradient normal to a wall ap FLUENT 0 July 26, 2004 08:32
