Evaporation in an Incompressible Lagrangian (LPT) solver? |
Jakob Heide
Rep Power: 0 ![]() |
Dear all,
I am trying to simulate an evaporating water spray in ambient air, i.e. no chemical reactions, in OpenFOAM 2.4. The only thread which is partly related could be http://www.cfd-online.com/Forums/ope...ble-flows.html . The code presented in that thread was written for OF 2.1 and it does not include evaporation. Ideally I would like the model to include:
So I guess I will need to create my own solver in case there is none available (?). How should I proceed? As I see it there are two options:
Thanks a lot! |
Jairo A. Gutiérrez S
Rep Power: 11 ![]() |
Hi, I am just having the same inconvenient. I would like to ask you if you were able of converting sprayFoam to an incompressible case? I did CFD simulations using sprayFoam in a spray dryer a couple of years ago but I am very interested in knowing if you obtain sightly different results using a "incompressible" version.
Rep Power: 10 ![]() |
Hey,
Has anyone managed to solve this problem? I want to inject water droplets in my computational domain. What I have done is coupled pimpleFoam solver with icoUncoupledKinematicLagrangianFoam which means that my solver now can do transient particle tracking. I have also added the energy equation in the modified solver. Now, I want to study the evaporation of water droplets by considering an 'incompressible' evaporation model. Can someone help me out with this? Best, Scram_1 |
Germany
Rep Power: 7 ![]() |
I also have this problem, did someone have done? |
Illia
Rep Power: 5 ![]() |
Hi guys. Is it 2020, anyone solved this inconvenience?
Thank you |
It looks there isnt still a incompressible-flow solver for sprays, but I ask, why was it mentioned that using a compressible flow - density-based solver gives a poor description?
Hosein
Rep Power: 14 ![]() |
Yeah it is also briefly mentioned in chapter 10.3 of Ferziger book that the methods for compressible flows will be inefficient for slightly compressible flows due to a different Courant number restriction... But not that they are giving a poor description though...
#8 | |
And regarding the "poor description" mentioned in the initial post, I completely agree with you. I have always seen it as integrating the drag contribution to describe the free fall of a ball inside a vacuum chamber. |
droplet, evaporation, incompressible, lagrangian |
Modify compressible solver to incompressible | mingzhao | OpenFOAM Running, Solving & CFD | 0 | September 18, 2015 12:50 |
Fully coupled solver (incompressible N.-S.) - Determinig pressure up to a constant | eltenedor | Main CFD Forum | 12 | November 12, 2014 14:44 |
Transition SST k-omega and solver choice for incompressible flow over wing | Aeronautics El. K. | FLUENT | 0 | August 4, 2014 18:33 |
Lagrangian Solver for N-S | harish | Main CFD Forum | 1 | May 12, 2005 08:43 |
Incompressible flow solver (staggered grid) | J. Ehrhard | Main CFD Forum | 1 | October 8, 1998 19:47 |
