dsmcFoam with a partially-reflecting patch
Old   August 5, 2016, 15:23
Default dsmcFoam with a partially-reflecting patch
Jacob Schwartz
vapormonger is on a distinguished road
I'd like to use dsmcFoam to model a system with walls that evaporate particles -- like a box with vacuum or low pressure inside, but the walls are coated with water held at a constant temperature.
From my understanding, a FreeStream boundary emits a Maxwellian distribution of particles, so the emission from evaporating surface could be modelled by FreeStream boundary with U=(0,0,0).
But, FreeStream absorbs all particles that hit it. I'd like to have walls/patches that emit particles like FreeStream, but have some chance of absorption and some chance of a wall interaction, for example MixedDiffuseSpecular.
Would be possible? How might I modify the code to allow this new boundary condition? I was thinking that DsmcParcel would be the main place to modify, by overriding one of the hitPatch functions of Particle to be similar to the hitWallPatch function.
Even better would be for different patches to have different probabilities of absorption vs bouncing, based on some dict.
vapormonger is offline   Reply With Quote
Old   August 5, 2016, 23:52
Ehsan
ehsan is on a distinguished road
Dear Jacob,
Have a look at the paper below, it suggest a simple but an efficient method:
citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.50.8229
So, create a new wall sub-model which inherits some features from free stream but injects particles from a different distribution function, like that in the paper, and then some part of the particles reflect from this wall with a probability of 1-S_e, and other particles absorb this wall with a probability of S_e.
Regards
Ehsan
ehsan is offline   Reply With Quote
boundaries, dsmc openfoam dsmcfoam, dsmcinitialize
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
