lagrangian time step
Old   March 1, 2019, 15:42
Default lagrangian time step
Tehran
sccience is on a distinguished road
would you please give me a hint about following issue:
how can I modify lagrangian time steps in openfoam. it seems that lagrangian and eulerian time steps are the same. i mean how can i set the solver time step for example at 0.0001s and lagrangian time step at 0.001s.?
sccience is offline   Reply With Quote
Old   August 1, 2019, 18:09
Utkan Caliskan
dscian is on a distinguished road
It's unusual to have smaller CFD timestep than particle timestep though. There is maxCo (default 0.3) definition in Lagrangian solvers which creates step fractions in CFD timestep for Lagrangian calculations which means you can have smaller timesteps using this. So I don't think it's possible to skip lagrangian calculations in CFD timestep. Moreover, I don't know what happens if maxCo is bigger than 1.
Other option would be to use some other CFD-DEM coupling where you use OpenFOAM and other DEM software such as LIGGGHTS so that you can define DEM timestep yourself.
dscian is offline   Reply With Quote
Old   August 1, 2019, 18:43
Tehran
Thank you for your reply. I made a mistake in my first post. I want to make lagrangian time step smaller than eulerian ones. As you know maybe there is not need to couple lagarngian and eulerian solvers in every time steps. So this can be vey cost effective.
dem-cfd, eulerian-lagrangian, lagrangian method, openfoam
Time Step Continuity Errors simpleFoam Dorian1504 OpenFOAM Running, Solving & CFD 1 October 9, 2022 09:23
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
