wallHeatFluxIncompressible compile error under OpenFoam for Windows 16.02
Old   June 7, 2016, 19:21
Default wallHeatFluxIncompressible compile error under OpenFoam for Windows 16.02
Vilma62
Vilma62 is on a distinguished road
When tried to compile the wallHeatFluxIncompressible utility (OF2.3 release by Bruno Santos), the following error message appears (undefined reference to `Foam::incompressible::turbulenceModel::typeName' collect2: error: ld returned 1 exit status):
$ wmake
Making dependency files...
x86_64-w64-mingw32-g++ -m64 -Dcygwin64 -DWM_DP -DMSWIN -DLITTLE_ENDIAN -Wall -Wextra -Wno-unused-parameter -Wnon-virtual-dtor -O3 -DNDEBUG  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/MSWindows/lnInclude   -Wl,--enable-auto-import,--enable-auto-image-base,--force-exe-suffix,--strip-all Make/cygwin64mingw-w64DPOpt/wallHeatFluxIncompressible.o -L/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/lib \
     -lincompressibleTransportModels -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools  -lOpenFOAM    -lm -o /opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/wallHeatFluxIncompressible.exe
Make/cygwin64mingw-w64DPOpt/wallHeatFluxIncompressible.o:wallHeatFluxIncompressible.C:(.text.startup+0xdd4): undefined reference to `Foam::incompressible::turbulenceModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&)'
Make/cygwin64mingw-w64DPOpt/wallHeatFluxIncompressible.o:wallHeatFluxIncompressible.C:(.rdata$.refptr._ZN4Foam14incompressible15turbulenceModel8typeNameE[.refptr._ZN4Foam14incompressible15turbulenceModel8typeNameE]+0x0): undefined reference to `Foam::incompressible::turbulenceModel::typeName'
/opt/OpenFOAM/OpenFOAM-2.3.x/wmake/Makefile:155: recipe for target '/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/wallHeatFluxIncompressible.exe' failed
make: *** [/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/wallHeatFluxIncompressible.exe] Error 1
Any help would be greatly appreciated.
Thanks in advance.
Vilma62 is offline   Reply With Quote
Trying to compile custom solver "turbineALSource" in OpenFOAM 2.2 mohsen.boojari OpenFOAM Programming & Development 1 April 16, 2016 16:35
How to install Overture library and compile it with OpenFOAM sagarg Lounge 0 August 15, 2015 05:20
[OpenFOAM.org] OpenFoam 2.1.1 not completely works in Debian jessie keepfit OpenFOAM Installation 1 July 18, 2015 17:46
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
How to compile OpenFOAM from scratch bashrc and cshrc danieltourde OpenFOAM Installation 2 December 15, 2006 09:30
