Implementation of trip in Boundary Layer flow
Like Tree1Likes
  • 1 Post By mAlletto
Old   August 29, 2018, 17:01
Exclamation Implementation of trip in Boundary Layer flow
Pedro
pedramtx is on a distinguished road
Hi All,
I am trying to implement a numerical tripping by applying a Gaussian force in the wall-normal direction in OpenFOAM. The reason for this implementation is that I'd like to force the transition to turbulence in flat plate boundary layer flow. This idea can be done by adding a term to the momentum equation of the solver. The volume force has been defined in Schlatter and Orlu (2012) "Schlatter, P., & Örlü, R. (2012). Turbulent boundary layers at moderate Reynolds numbers: inflow length and tripping effects. Journal of Fluid Mechanics, 710, 5-34."
I am seeking help regarding implementation of this force defined in spectral domain (the ineverse Fourier) into the momentum equation in physical domain. Any help is greatly appreciated.
Thanks,
Pedram
pedramtx is offline   Reply With Quote
Old   September 5, 2018, 12:41
Michael Alletto
mAlletto will become famous soon enough
Just from the picture you showed it seems that the force is a function of x,y,z,t. The random numbers h are function of z and t. Can you provide some more detail?
mAlletto is offline   Reply With Quote
Old   September 5, 2018, 12:55
Pedro
Hi Michael,
You are right. The random force g is a function of z and t. I want to apply a 1D wavenumber in the spanwise direction. Then the whole term F is expressed by a local Gaussian distribution in z plane.
Old   September 6, 2018, 02:01
Michael Alletto
Maybe I did not und understand correctly the question.
Old   September 13, 2018, 03:18
Michael Alletto
I found by accident this post of Schlatter where he explains how he generated the random harmonic signal: https://lists.mcs.anl.gov/pipermail/nek5000-users/2018-February/005087.html
in order to generate the random source term in order to simulate the boundary layer tipping.
pedramtx likes this.
Old   September 13, 2018, 12:42
Pedro
Thank you, Michael. This is so helpful.
Old   September 14, 2018, 11:08
Michael Alletto
You're welcome
Let me know how it goes. I find the topic interesting
Old   September 18, 2018, 03:37
Agustín Villa
agustinvo is on a distinguished road
Very interesting topic! I will follow it. It is also interesting for me. For the moment, what I do is to use swak4Foam and introduce some disturbances in the wall.
agustinvo is offline   Reply With Quote
Old   September 18, 2018, 22:26
Pedro
Agustín,
Thank you for your suggestion. Still trying to make it work.
Old   September 20, 2018, 03:06
Syavash Asgari
syavash is on a distinguished road
Why not use a more sophisticated method like LeMOS or SEM at the inlet? Or a step further ahead, use the method introduced by Lund et al. (JCP 1998) in your simulation.
Regards,
Syavash
syavash is offline   Reply With Quote
Old   September 20, 2018, 03:14
Agustín Villa
Regards,
Syavash
Hi Syavash,
my case is a natural convection boundary layer, not a forced convection one. The boundary layer starts developing when the wall is heated. If I introduce an inlet flow, I'd have a mixed convection case.
I will check later the different approaches you said, I have some colleagues who may be interested.
Agustín
Old   September 20, 2018, 03:20
Syavash Asgari
Hi Syavash,
Agustín
Agustin,
Having a naturally developing boundary-layer to turbulence should be very interesting, and challenging! Actually I got very interested in this problem. Could you please provide me a snapshot of your simulation? Also would you introduce me a paper dealing with the same problem using LES?
Regards,
Syavash
Old   September 20, 2018, 10:07
Pedro
Regards,
Syavash
Syavash,
Thank you for your suggestion. We already captured the turbulent BL using Lund method, but the current simulation aims at resolving the transition behavior of BL. As you may know, rescaling procedure in Lund method necessitates equilibrium state (developed turbulent field) at recycling station.
Thanks,
Pedram
Old   September 15, 2022, 10:20
Jin Zhang
sjlouie91 is on a distinguished road
Originally Posted by pedramtx View Post
Agustín,
Hi Pedram,
I also find this numerical tripping quite interesting. Although it's been a long time since you last posted, I am still very curious about how this method is implemented in OpenFOAM. Have you already solved this problem? I would appreciate it if you could share your code or give me some clues on how to implement it. Thanks.
kind regards,
Jin
sjlouie91 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
