Calculation of gradient only for subset of cells to improve performance
Prev Previous Post   Next Post Next
Old   July 11, 2016, 09:35
Default Calculation of gradient only for subset of cells to improve performance
Lennart
elmo555 is on a distinguished road
Hello Foamers,
is there a way to calculate the gradient (or any other OF tensor operation) for only a subset of cells that fulfill a given condition? In my case, I need a concentration gradient Xv only near the phase interphase, that is where eps < alpha1 < 1-eps.
Since most of the cells in the domain are not close to the interface, calculating the gradient in them is a waste of computational time.
I can easily limit normal calculations to the required cells using:
forAll(alpha1, celli) {
    if(alpha1[celli] > eps && alpha1[celli] < 1-eps) {
        // ... calculation ...
Is there a similar way for the gradient (without manually computing it - I would like to stick with the OF-implementation fvc::grad)?
elmo555 is offline   Reply With Quote
conditional, conditional computation, gradient, limit
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 11:57
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Gradient calculation in CFD apurva shukla Main CFD Forum 1 August 21, 1998 07:05
