Anisotropic, implicit momentum source term
Old   June 11, 2013, 06:58
Default Anisotropic, implicit momentum source term
Chris Meyer
chris_j_meyer is on a distinguished road
Hi All
Will not bore you with the details, but I am adding a momentum source term that is anisotropic. To do this explicitly is quite easy as a volVectorField with the sources can just be added to the U-equation. For an implicit formulation the following can be used and added to the U-equation:
fvm::Sp(a, U)
However, "a" can at best be a volScalarField and hence the source will be locally isotropic. Is there any way in which I can add different implicit source terms to the momentum equations in the three coordinate directions?
Chris
chris_j_meyer is offline   Reply With Quote
Old   June 11, 2013, 10:56
Lieven
Lieven will become famous soon enough
Hi Chris,
Have a look at the implementation of the porous media source term. I think this is what you are looking for.
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   July 18, 2013, 18:42
ski
AS
ski is on a distinguished road
I'd like to do this too..
Issue is that it appears to be using Jacobi method to solve, which tends to give poor convergence rates. Anyone have any experience on this?
ski is offline   Reply With Quote
Old   July 25, 2016, 16:11
Question Did anyone find a way to program an implicit anisotropic source???
Mateus Palharini Schwalbert
mateusps is on a distinguished road
Hello y'all,
I have the same problem: how to program an anisotropic implicit source in the momentum equation?
fvm::Sp simply does not accept a tensor as coefficient (fvm::Sp(tensor,vector) does not seem to be implemented).
Did anyone find a way?
Thanks
mateusps is offline   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
How does fluent handles the momentum source term? QBeast FLUENT 0 April 22, 2013 14:12
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Momentum source UDF Matthew Brannock FLUENT 5 May 3, 2001 21:18
